fos4 PANEL ETL 8 LUSTR FIXT (2-TONE)
Was: $5,975.00
Now: $3,630.00
SKU:
7471A1000
Previously used unit
Includes 90 day warranty.
The smallest in its series, this 8"x24" fos/4 panel uses Lustr X8, an eight color LED array. Designed with the cinematic workflow in mind, ETC's fos/4 panels are simple and intuitive without compromising efficiency. Even new users can quickly and accurately adjust settings using the four backlit encoders that change colors to correspond to the attributes they control on the screen. Have the option to change your fixture’s default philosophy with the fos/4. Generally with additive color, the fixture decides how to mix the color requested and chooses to mix the brightest version of the color, giving intensity not quality light. The fos/4 lets you decide what you want to see using the tune functionality, choose brightest, best spectral, or hybrid – which gives you a balance of the two. Among the various control options, the fixture features wireless built-in including near field communication (NFC) to be used in conjunction with ETC’s Set Light app from your mobile phone or tablet, even when the fixture isn’t powered, plus City Theatrical’s Multiverse wireless DMX control. Render skin tones, sunsets, and moody saturated scenes better with eight colors of LEDs, deep red, red, amber, green, cyan, blue, indigo, and lime. The deep red is the deepest red from the the corners of the CIE color space and is essential to accurately capture the warm glow of firelight, romance at sunset, and the most nuanced skin tones. The fos/4 gives predictable nuanced color from reality, to the camera, to the screen and is brighter at nearly all color points.
ETC FOS4PL8 Includes:
  • fos/4 Panel
  • Aluminium yoke with 2 mounting positions and regional mounting hardware
  • 5' Neutrik True1 power cable with Edison connector
  • Standard Diffusion
ETC FOS4PL8 Features:
  • Intuitive UI
  • Color control
  • Wireless control
  • Thoughtful design
  • Deep Red
ETC FOS4PL8 Specifications:
  • Type: Color-mixing high-intensity LED illuminator
  • Optical: Full homogenized
  • LEDs: Luxeon® C LED emitters
  • Lustr X8 Array: Deep Red, Red, Amber, Green, Cyan, Blue, Indigo, Lime
  • Minimum Number of LEDs: 336
  • CCT: 1,900 K-10,450 K
  • PWM Frequency: 20,000 Hz
  • L70 Rating: 54,000 hours
  • Aperture: 8"x24"
  • Dimming: 15-bit; nonlinear scaling
  • Control: USITT DMX 512A
  • Protocol:
    • DMX
    • RDM
  • DMX Input Profiles:
    • RGB
    • Single Channel
    • Expanded-Full
    • Direct
    • Studio
  • User-definable Options: Yes
  • Local Control Modes: Yes
  • Stand-along Functionality: Yes; up to 32 fixtures may be linked
  • Display: Color LCD with two-button, 4 encoder user-interface
  • Hard Lockout Switch: Yes
  • Power: 100 V-240 V 50/60 Hz internal power supply
  • Ambient Temperature Range: 0°C-40°C (32°F-104°F)
  • Connections:
    • 5-pin XLR: Control in/thru
    • Neutrik True1: Power in/thru
    • 4-pin XLR: 24-36 VDC Battery support
    • USB: Software updates, diagnostic reports, and configuration saving/loading
    • City Theatrical Multiverse: Yes
    • Near Field Communication (NFC): Yes
  • Qualifications/Ratings:
    • USITT DMX-512A standard
    • ETL Listing: UL 1573 for stage and studio
    • IP Rating: IP20
  • Physical:
    • Construction: Die cast aluminum
    • Finish: 2-tone black/studio gray powder coat
  • Warranty:
    • Full fixture coverage: 5 years
    • LED coverage: 10 years
  • Available Accessories (sold separately):
    • Diffusion:
      • Light
      • Heavy
      • Intensifier
    • Barn Door
    • Egg Crates:
      • 40°
      • 50°
      • 60°
    • Chimera Pop Bank
Videos Hide Videos Show Videos
