S4 LED FRONT BARREL ASSEMBLY KIT BLK
Was: $100.00
Now: $85.00
SKU:
7460A2007-K
Condition:
Used
Previously used unit
Includes 90 day warranty.
This Shutter Barrel kit connects your ETC LED Light Engine or HPL-based Tungsten Reflector Housing with traditional Standard/EDLT Source Four Lens Tubes.  Both LED/HPL versions feature the same parts, the only difference is which Source Four sticker is affixed to the shutter barrel.
  • Easily install with a phillips screwdriver in less than a minute
  • Primarily for using existing Standard/EDLT lens tubes with the Source Four LED Series 3
  • Designed for use with the following:
    • Source Four LED Series 3 ("LED Engine Only" option, plus this Shutter Barrel Kit)
    • Source Four LED Series 2 and Series 1 ("LED Engine + Shutter" option)
    • All versions of Source 4WRD ("LED Engine + Shutter" option)
    • ColorSource Spot and Spot V ("LED Engine + Shutter" option)
    • Source Four ERS (Tungsten/HID)
