Previously used unit
Includes 90 day warranty.
Modules are AF (Advanced Features sensing). When AF modules are used with a CEM+ (Control Electronics Module) the system becomes so powerful it can tell you if a lamp has burned out or if there is a problem with a dimmer. The CEM+ receives and manages Ethernet control signals as well as two DMX512 inputs. It controls dimmer output and gives feedback information to compatible lighting control devices and network peripherals. 128 programmable presets, set dimmer curve, and even set air filter cleaning reminder.
