Previously used unit
Includes 90 day warranty.
GENERAL INFORMATION
The Source Four LED Series 2 is the evolution of LED lighting. While it may look the same on the outside, the Series 2 offers even more of what makes the Source Four LED the best LED profile available. With optimized arrays and finely-tuned electronics, the Series 2 offers a combination of light quality and output that cannot be matched.
Source Four LED Series 2 Daylight HD arrays are designed for broadcast lighting, offering flicker-free operation and high-definition lighting. With a new mix of LED emitters, the luminaires’ output is significantly brighter than the original Source Four LED white-light arrays. The Daylight HD array produces variable-cool white (4000 to 6500K) light that imitates natural daylight. They offer tint control, so they can be tweaked to perfectly illuminate individual skin tones.
Series 2 light engines work with all Source Four lens tubes to deliver a high-quality, controllable beam of LED light. For the best results, it is highly recommended that EDLT versions are used. We also offer a special LED-only version of the 50° lens tube.
GENERAL
- 60-LED array
- ETL listed to UL1573 – the standard for stage and studio lighting units
- IP20-rated for indoor use
- Power and DMX in/thru connections for easy setup
- User-friendly control interface with multiple modes and fixture settings
PHYSICAL
- Rugged die-cast all-metal housing
- Available in black (standard), white or silver gray or custom colors (contact factory)
- C-clamp
- Positive-locking double-clutch fixture body
- Slot for glass or stainless steel patterns and soft-focus diffuser
- Wide accessory slot with sliding cover for motorized pattern devices or optional iris
- Hanging yoke standard. Optional yoke/floor-stand available
ELECTRICAL
- 100VAC to 240VAC 50/60Hz universal power input
- Neutrik power in and thru connections
- Up to seven Daylight HD luminaires (15A max) may be linked via power thru connector (Daylight HD fixtures total per circuit) when used with R20 Relay Module or Unison® Echo™ Relay Panel
- Consult breaker-trip curves when used with other equipment. Requires power from a non-dim source
- Inrush
- 120V: 50A (First half-cycle)
- 240V: 107A (First half-cycle)
LED
- Daylight HD: 20000-hour LED life (20,000 hours to 70% intensity)
- 60 Luxeon® Rebel LED emitters
COLOR
- Selection from the x7 Color System to provide high quality, variable-white light
- Daylight HD (4000K-6500K)
- Beautifully illuminates skin tones and other objects for natural appearance and high color rendering
- Broad-spectrum color interacts seamlessly with conventional sources
- Exclusive optional red-shift option emulates tungsten dimming performance
OPTICAL
- Use the included soft-focus diffuser for creating washes or soft light
- Best performance using ETC’s EDLT lens tubes
- Can use all ETC Source Four interchangeable lens barrels: 5°, 10°, 14°, 19°, 26°, 36°, 50°, 70°, and 90° field angles, as well as 19°, 26°, 36°, and 50° EDLT lenses
- For better performance, use the LED 50° barrel
CONTROL
- DMX512 in and thru via five-pin XLR connectors
- Multiple control options, including RGB, strobe, and console-free Master/Slave mode
- See DMX Control Table for additional information
- 15-bit virtual dimming engine provides smooth, high-quality theatrical fades and minimizes color shift during dimming
- RDM functionality for address and setting changes
THERMAL
- Ambient operating temperature of 32° to 104°F (0° to 40°C)
- Active electronic thermal management for droop-free operation
- Quiet fan cooling
- Fixture is designed for continuous operation up to 104°F (40°C) ambient temperature and requires free flow of air around fixture housing
