ACC USB DMX SUPER DUPER WIDGET
$2,041.00
SKU:
62040005
Availability:
Usually ships in 7-10 business days. Expedited shipping options are not available through the website. For faster shipping methods or deliveries to international locations, Alaska, Hawaii, or U.S. Outlying Territories, please contact Customer Service
Previously used unit
Includes 90-day warranty - if the used item fails within this period, it may be returned for a refund or a warranty repair.
GENERAL INFORMATION
The USB DMX Super Duper Widget from High End Systems is a 19 inch rack-mountable model that provides 8 universes of DMX 512 output from any Hog 4 OS consoles (except Road Hog 4 where it will only allow 4 universes) and any Hog 4 PC. When used in conjunction with Hog 4PC software, 1 DMX Super Duper Widget may be connected to provide 8 full universes of DMX 512. This configuration provides an excellent solution for backup and playback only applications. By adding Nano Hog 4, Playback Wing 4 and Master Wing 4, users can configure powerful control solutions that precisely suit their needs and budgets.
For Hog 4 PC users, attaching the DMX Super Duper Widget also unlocks 8 universes of DMX over Art-Net and E1.3.1 (sACN).
FEATURES
  • USB connection to any Hog 4 console as well as Hog 4 PC
  • 19" Rackmount form factor
  • Eight DMX-512 outputs on 5-pin XLR connectors
  • Supports up to 4096 output channels
  • Kensington security slot
  • One USB input connector
  • Storage Temperature 20-60°C / 0-140°F
  • Compliance: ETL, CETL, CE
ELECTRICAL
  • Mains power: 100-250VAC, 50/60Hz, max 200W
  • Mains connector:  IEC320 C13
  • Fuse: 1x 5x20mm 5AT fuse
 WEIGHTS AND DIMENSIONS
  • Width: 483mm / 19.1"
  • Depth: 277mm / 10.9"
  • Height: 45mm / 1.75"
  • Weight: 2.6kg / 5.75lb
