CS FRESNEL V XLR ETL W/MVERSE SILVER
$746.50
SKU:
7417A1011-5
Condition:
Used
Availability:
Previously used unit
GENERAL INFORMATION
SILVER FIXTURE
An LED luminaire crafted by lighting experts with a proven history of quality fixtures, ColorSource Fresnel V brings a richness of color, increased brightness, and leading technology at a price point you’ll love. Featuring a five-color array of red, green, blue, indigo, and lime, the ColorSource Fresnel V provides soft pastels and bold saturated colors from a single fixture. Control the motorized 13°–44° zoom using DMX or manually from the rear of the fixture. ColorSource Fresnel V also features wireless DMX/RDM control using Multiverse® technology, NFC configuration from your mobile device, and next level brightness, making it the ultimate in affordable wash light technology.
FEATURES
  • Five-color array (red, green, blue, indigo, and lime)
  • Motorized 13–44 degree zoom with DMX and local control
  • Simple user interface with seven-segment display
  • powerCON® TRUE1® TOP connector
  • DMX/RDM in and thru (5-pin XLR)
  • Multiverse wireless DMX/RDM
  • NFC (near field communication) configuration
  • LED droop compensation
  • Optically calibrated
  • Tour-ready, aluminum housing
APPLICATIONS
  • Theatres and performance spaces
  • Houses of worship
  • Universities and schools
  • Hospitality
  • Retail
  • Exhibition centers
  • Meeting rooms
  • Clubs
  • Cafetoriums
SOURCE
  • LED details 44 Lumileds LUXEON® C LEDs
  • Max lumens 5330
  • Lumens per watt 36
  • L70 rating (hours to 70% output) 54,000 hours
COLOR
  • Colors used Red, Green, Blue, Indigo , Lime
  • Color temperature range Color mixing
  • Calibrated array
OPTICAL
  • Beam angle range 13°–44°
  • Aperture size 190 mm (7.48 in)
  • Camera flicker control/Hz range 5,000 Hz (default) and 25,000 Hz (via RDM)
CONTROL
  • Input method 5-Pin XLR, Multiverse wireless (optional), and NFC
  • Protocols DMX-512, RDM, City Theatrical Multiverse (optional), NFC
  • Modes (footprint) 4 modes
  • RDM configuratio
  • UI type Seven-segment display, three-button interface, Focus encoder
  • Local control
  • Onboard presets Yes (12)
  • Onboard sequences Yes (5)
  • FixtureLinK
  • Notes 15-bit virtual dimming engine
WIRELESS
  • Band 2.400–2.480 GHz
  • Range 100 m indoors, 500 m line of sight (subject to conditions)
  • Max receivers DMX: No limit
  • RDM: Varies by transmitter used
  • Multiverse SHoW Baby®: 585
  • Multiverse Transmitter: 5,000
  • Broadcast power 100 Mw
ELECTRICAL
  • Voltage range 100–240 VAC 50/60 Hz
  • Input method powerCON TRUE1 TOP power in and thru
  • Inrush (first half-cycle) 120 V: 36 A, 240 V: 57 A
  • Fixtures per circuit on standard R20 breaker
  • 9 (link up to 8 via Power Thru connector)
  • Note: TRUE1 connector rated for 20 A (120 V / 60 Hz) and 16 A (240 V / 50 Hz)
  • Wattage (typical) 120 V: 148.4 W, 230 V: 147.0 W
  • Current draw 120 V: 1.28 A, 230 V: 0.70 A
THERMAL
  • Ambient operating temp 0°C–40° C (32°F–104° F)
  • Fan (controllable) Yes (yes)
  • Droop compensation
  • Average dB 22.7 dBA
  • BTUs/hour (120 V) 508
PHYSICAL
  • Materials Cast and extruded aluminum
  • Color Silver
  • Yoke Mounting options
  • IP rating IP20
  • Weight 6.24 kg (13.75 lb)
  • Included accessories Yoke, power cable
