Previously used unit
GENERAL INFORMATION
WHITE FIXTURE
An LED luminaire crafted by lighting experts with a proven history of quality fixtures, ColorSource Fresnel V brings a richness of color, increased brightness, and leading technology at a price point you’ll love. Featuring a five-color array of red, green, blue, indigo, and lime, the ColorSource Fresnel V provides soft pastels and bold saturated colors from a single fixture. Control the motorized 13°–44° zoom using DMX or manually from the rear of the fixture. ColorSource Fresnel V also features wireless DMX/RDM control using Multiverse® technology, NFC configuration from your mobile device, and next level brightness, making it the ultimate in affordable wash light technology.
FEATURES
- Five-color array (red, green, blue, indigo, and lime)
- Motorized 13–44 degree zoom with DMX and local control
- Simple user interface with seven-segment display
- powerCON® TRUE1® TOP connector
- DMX/RDM in and thru (5-pin XLR)
- Multiverse wireless DMX/RDM
- NFC (near field communication) configuration
- LED droop compensation
- Optically calibrated
- Tour-ready, aluminum housing
APPLICATIONS
- Theatres and performance spaces
- Houses of worship
- Universities and schools
- Hospitality
- Retail
- Exhibition centers
- Meeting rooms
- Clubs
- Cafetoriums
SOURCE
- LED details 44 Lumileds LUXEON® C LEDs
- Max lumens 5330
- Lumens per watt 36
- L70 rating (hours to 70% output) 54,000 hours
COLOR
- Colors used Red, Green, Blue, Indigo , Lime
- Color temperature range Color mixing
- Calibrated array
OPTICAL
- Beam angle range 13°–44°
- Aperture size 190 mm (7.48 in)
- Camera flicker control/Hz range 5,000 Hz (default) and 25,000 Hz (via RDM)
CONTROL
- Input method 5-Pin XLR, Multiverse wireless (optional), and NFC
- Protocols DMX-512, RDM, City Theatrical Multiverse (optional), NFC
- Modes (footprint) 4 modes
- RDM configuratio
- UI type Seven-segment display, three-button interface, Focus encoder
- Local control
- Onboard presets Yes (12)
- Onboard sequences Yes (5)
- FixtureLinK
- Notes 15-bit virtual dimming engine
WIRELESS
- Band 2.400–2.480 GHz
- Range 100 m indoors, 500 m line of sight (subject to conditions)
- Max receivers DMX: No limit
- RDM: Varies by transmitter used
- Multiverse SHoW Baby®: 585
- Multiverse Transmitter: 5,000
- Broadcast power 100 Mw
ELECTRICAL
- Voltage range 100–240 VAC 50/60 Hz
- Input method powerCON TRUE1 TOP power in and thru
- Inrush (first half-cycle) 120 V: 36 A, 240 V: 57 A
- Fixtures per circuit on standard R20 breaker
- 9 (link up to 8 via Power Thru connector)
- Note: TRUE1 connector rated for 20 A (120 V / 60 Hz) and 16 A (240 V / 50 Hz)
- Wattage (typical) 120 V: 148.4 W, 230 V: 147.0 W
- Current draw 120 V: 1.28 A, 230 V: 0.70 A
THERMAL
- Ambient operating temp 0°C–40° C (32°F–104° F)
- Fan (controllable) Yes (yes)
- Droop compensation
- Average dB 22.7 dBA
- BTUs/hour (120 V) 508
PHYSICAL
- Materials Cast and extruded aluminum
- Color White
- Yoke Mounting options
- IP rating IP20
- Weight 6.24 kg (13.75 lb)
- Included accessories Yoke, power cable
