Previously used unit
GENERAL INFORMATION
ColorSource PAR Pearl is a variable white-light LED wash fixture that utilizes a mix of two different white LEDs. This mixture enables you to set
the color temperature anywhere between 2700 K and 6500 K. The Pearl array provides the same great feature set and high quality construction
as its full color siblings, including an impressively bright output and simple user interface.
Designed for installations that depend heavily on white light such as studios, houses of worship, and architectural installations, this array
features flicker-free operation and a smooth dimming curve.
APPLICATIONS
- Theatres and performance centers
- Houses of worship
- Universities and schools
- Studios
- Hospitality
- Retail
- Exhibition centers
- Meeting rooms
- Clubs
PRODUCT FEATURES
- Variable CT from 2700 K to 6500 K
- Homogenized optics
- Simple user interface with seven-segment display
- powerCON in and thru
- 5-pin XLR
- LED droop compensation
- Optically calibrated
- Tour-ready, aluminum housing
PRODUCT SPECIFICATIONS
Source
- LED details 40 Lumileds LUXEON® Z LEDs
- Max lumens 5,709
- Lumens per watt 50
- L70 rating (hours to 70% output)* >60,000 hours
Color
- Colors used Warm white, cool white
- Color temperature range 2700–6500 K
- Calibrated array
Optical
- Beam angle range 15 degrees
- Aperture size 190 mm (7.5 in)
- Camera flicker control/ Hz range 1,200 Hz (default) and 25,000 Hz (via RDM)
Control
- Input method DMX-512 via 5-pin XLR connector
- Protocols DMX512, RDM
- Modes (footprint) 3 modes
- RDM configuration
- UI type Seven-segment address display
- Local control
- Onboard presets Yes (12)
- Fixture to fixture control
- Notes Local level control via UI
*All LED sources experience some lessening of light output and some color shift over time. LED output will vary with thermal conditions. In individual situations, LEDs will be used for different durations and levels. This can eventually lead to minor alterations in color performance, necessitating slight adjustments to presets, cues or programs.
Electrical
- Voltage range 100–240 VAC, 50/60 Hz
- Input method powerCON in and thru
- Inrush 35 A (first half-cycle) at 120 V, 49 A (first half-cycle) at 230 V
- Fixtures per circuit* 10 (20 A switched circuit, R20 module or similar)
- Wattage (typical / standby) - 114 W / 1.6 W at 120 V, 112 W / 1.5 W at 230 V
- Current draw 0.96 A at 120 V, 0.50 A at 230 V
*Note: All measurements are for 120 V, 60 Hz. Results may vary in different regions.
Thermal
- Ambient operating temperature 0°C to 40°C (32°F to 104°F)
- Fan Yes
- Droop compensation
- dB range 24.8 dBA average at 1 m
- BTUs/hour 389
Physical
- Materials Die-cast all metal housing
- Black Color
- Mounting options Yoke or floor stand (as optional accessory)
- IP rating IP20
- Weight 3.77 kg (8.3 lb)
- Included accessories Hanging yoke, power cable
Regulatory and Compliance
- Approved regulatory standards
- cETLus Listed
- Conforms to UL 1573 Listed
- Conforms to UL 924 Listed
- Certified to CSA C22.2 No. 166 Listed
- Certified to CSA C22.2 No. 141 Listed
- CE Compliant
- EAC Compliant
