Previously used unit
White Fixtures
GENERAL INFORMATION
ColorSource Spot Pearl is a variable white-light LED array that utilizes a mix of two different white LEDs. This mixture enables you to set the color temperature anywhere between 2700 K and 6500 K. The Pearl array includes the same great feature set and high-quality construction as its full color siblings, including an impressively bright output and simple user interface. Designed for installations that depend heavily on white light such as studios, houses of worship, and architectural installations, this array features flicker-free operation and an incredibly smooth dimming curve.
Does NOT include Lens Tube.
APPLICATIONS
- Houses of worship
- Universities and schools
- Studios
- Hospitality
- Retail
- Exhibition centers
- Meeting rooms
- Clubs
PRODUCT FEATURES
- Variable white light using 2700 K and 6500 K LEDs
- Simple user interface with seven-segment display
- powerCON® in and thru
- DMX/RDM in and thru (5-pin XLR)
- Optically calibrated
- Tour-ready, aluminum housing
- Combine with available adapters to transform your fixture into a fully functional Fresnel or CYC light
