Previously used unit
GENERAL INFORMATION
An IP65 rated LED luminaire crafted by lighting experts with a proven history of manufacturing quality spot fixtures, ColorSource Spot VXT brings a richness of color, increased brightness, and leading technology at a price point you’ll love – now for outdoor venues. Featuring a five-color array of red, green, blue, indigo, and lime, the ColorSource Spot VXT provides soft pastels and bold saturated colors from a single fixture.
Make installs more efficient by configuring your Spot VXT fixtures wirelessly using the free Set Light app and NFC from your mobile device. And, you can use your existing inventory of Source Four lens tubes and accessories on your new Spot VXT fixtures!
APPLICATIONS
- Outdoor theatres and performance spaces
- Houses of worship
- Universities and schools
- Facade lighting
- Retail
- Exhibition centers
- Meeting rooms
- Clubs
- Cafetoriums
PRODUCT FEATURES
- Five-color array (red, green, blue, indigo, and lime)
- IP65 rated housing
- powerCON® TRUE1® TOP connector
- DMX/RDM in and thru (5-pin XLR)
- Multiverse ® wireless DMX/RDM
- NFC (near field communication) configuration
- LED droop compensation
- Optically calibrated
- Tour-ready, aluminum housing
- Combine with available adapter to transform your fixture into a fully functional CYC light
PRODUCT SPECIFICATIONS
Source
- LED details 60 Lumileds LUXEON® C and LUXEON Rebel LEDs
- Max lumens 8,896
- Lumens per watt 37.3
- L70 rating (hours to 70% output)* 54,000 hours
Color
- Colors used Red, green, blue, indigo, lime
- Color temperature range Color mixing
- Calibrated array
Optical
- Beam angle range Swappable lens tubes, 5–90 degrees
- Gate size 80 mm
- Aperture size 6.25–14 in (depending on lens tube)
- Pattern projection
- Pattern size A or B
- Camera flicker control/Hz range 5,000 Hz (default) and 25,000 Hz (via RDM)
Notes Can use LED CYC adapter, Fresnel adapter NOT supported
Control
- Input method 5-Pin XLR (IP rated), Multiverse wireless and NFC
- Protocols DMX-512, RDM, City Theatrical Multiverse, NFC
- Modes (footprint) 5 modes
- RDM configuration
- Local control via Set Light only
- Onboard presets (12)
- Onboard sequences (5)
- FixtureLink
- Notes 15-bit virtual dimming engine
Wireless
- Band 2.400–2.480 GHz
- Range 100 m indoors, 500 m line of sight (subject to conditions)
- Max receivers DMX: No limit, RDM: Varies by transmitter used, Multiverse SHoW Baby®: 585, Multiverse Transmitter: 5,000
- Broadcast power 100 mW
Electrical
- Voltage range 100–240 VAC 50/60 Hz
- Input method powerCON TRUE1 TOP power in and thru
- Inrush 7.02 A at 120 V (First half-cycle), 19.5 A at 240 V (First half-cycle)
- Fixtures per circuit* 6 fixtures (R20 module or similar)
- Wattage typical / standby 240.8 W / 3.6 W at 100 V, 238.5 W / 3.6 W at 120 V, 236 W / 2.9 W at 240 V
- Current draw typical / standby 2.45 A / 0.1 A at 100 V, 2.02 A / 0.11 A at 120 V, 1.06 A / 0.17 A at 240 V
*Note: All measurements are for 120 V, 60 Hz. Results may vary in different regions.
Thermal
- Ambient operating temp -20°C to 40°C (-4°F to 104°F)
- Fan (controllable)
- Droop compensation
- dB range 26.3 dBA average at 1 m
- BTUs/hour 813
Physical
- Materials Die-cast, all metal housing
- Color options Black, white, silver, or custom color
- Yoke Mounting
- IP rating IP65
- Weight 10.8 kg (23.7 lb) (without lens)
- Included accessories Hanging yoke, 1.5 m power cable, soft-focus diffuser in an A-size gobo holder
Warranty
- Fixture 5 years
- LED array 10 years
Regulatory and Compliance
- Approved regulatory standards: cULus Listed, CE and UKCA compliant
All LED sources experience some lessening of light output and some color shift over time. LED output will vary with thermal conditions. In individual situations, LEDs will be used for different durations and levels. This can eventually lead to minor alterations in color performance, necessitating slight adjustments to presets, cues or programs
