D22 DAYLIGHT EUTRAC TRK ETL FIX WHT
$544.00
SKU:
7411A1071-1
Availability:
Previously used unit
GENERAL INFORMATION
ETC’s Selador Desire D22 luminaire puts the x7 Color System into a compact, round washlight. Highly efficient primary lenses and careful color choices make the D22 fixture ideal for stage, studio, architecture and anywhere vibrant color and high intensity are requirements. The x7 Color System produces the widest range of spectrally-balanced saturated and tinted color choices available, while the static-white options provide an impressive punch. D22’s rugged die-cast enclosure, noiseless fan-free operation, multiple lens options, convenient size and advanced user interface make it an ideal addition to the Desire family of LED luminaires.
D22 LED Array
• D22 Studio Daylight: Contains twenty-two 5600 K LEDs for high-intensity, non-variable cool-white output
LED fixture
• D22 Track-Yoke: One Track or DataTrack adapter and a single, permanent cable for both power and DMX in.
PRODUCT SPECIFICATIONS
Source
  • LED details 22 Lumileds LUXEON® Rebel LED
  • Max lumens Studio Daylight: 2,533
  • Lumens per watt Studio Daylight: 50
  • L70 rating (hours to 70% output) 50,000 hours
Color
  • Colors used Studio Daylight: White
  • Color temperature range 2,700–6,500 K
  • Red shift
Optical
  • Beam angle 8°–71°
  • Aperture size 6 in
  • Camera flicker control/Hz range: 900–25,000 Hz
Notes Secondary lenses available for multiple beam-spread options
Control
  • Input method DMX512 via 5-pin XLR (portable only) Permanent power input cable
  • Protocols DMX-512/RDM
  • RDM configuration
  • UI type LCD
  • Local control
  • Onboard presets
  • Onboard sequences
  • Fixture-to-fixture control
Notes 15-bit virtual dimming engine
Control
  • Notes 15-bit virtual dimming engine
Electrical
  • Voltage range 100–240 VAC 50/60 Hz
  • Input method Requires power from a non-dimmable source
  • Portable: Edison, Schuko or UK13A connector
  • Inrush (over first half-cycle) 17 A at 120 V 25 A at 240 V Fixtures per circuit* 20 (R20 module or similar)
  • Wattage typical 56.5
  • Current draw 0.58 A at 110 V, 0.48 A at 120 V, 0.29 A at 230 V, 0.29 A at 240 V
*All measurements are for 120 V, 60 Hz. Results may vary in different regions.
Thermal
  • Ambient operating temp 0°–40° C (32°–104° F)
  • Droop compensation
  • BTUs/hour 192.778
Physical
  • Materials Die-cast, all metal housing
  • Color option White
  • Mounting option track-yoke
  • IP40 for track version
  • Weight 3.13 kg (6.9 lb)
  • Included accessories Hanging yoke
Regulatory and Compliance
  • Approved regulatory standards: UL 1573, CSA C22.2 No. 166, CE Compliant, EAC Compliant
