D40 STUDIO LED FIXTURE ETL BLK
$673.00
SKU:
7410A1402
Availability:
Previously used unit
GENERAL INFORMATION
ETC Desire D40 Studio lighting fixtures use the newest technology in high-output white-light LEDs to create an ideal luminaire for video, film and other ‘white light only’ applications. Three different LED options give the user a choice for just the right white-light output for the job.  The D40 Studio offers a rugged die-cast enclosure, noiseless fan-free operation, multiple lens options and an advanced user interface. The user interface enables easy configuration and specific features for video and film applications. The fixture can be configured to operate under console control for studio systems or in stand-alone ‘no console required’ mode for location lighting.
D40 STUDIO LED ARRAY OPTIONS
D40 Studio fixtures offer three different LED array choices based on specific white-light functions. The D40 Studio fixture is available with any one of the following arrays (not interchangeable) to best suit the intended application.
  • D40 Studio HD – combines warm-white and cool-white LEDs for variable color temperature mixing. Added to this are five carefully chosen LED colors from the Selador x7 Color System to fill in the white LED spectral gaps. The high-intensity D40 Studio HD provides the richest variable-white light possible in an LED fixture and excellent color rendering
PRODUCT SPECIFICATIONS
Source
  • LED details 40 Lumileds LUXEON® Rebel LED
  • Max lumens Studio HD: 3,194
  • Lumens per watt Studio HD: 33.2
  • L70 rating (hours to 70% output) 50,000 hours
Color
  • Colors used Studio HD: Red, Amber, Green/Cyan, Blue, Warm White, Cool White
  • Color temperature range Studio HD: 2700–5600 K
  • Calibrated array Studio HD
  • Red shift
  • Optical
  • Beam angle 11°
  • Aperture size 7.5 in
  • Camera flicker control/Hz range 900–25,000 Hz
Notes Secondary lenses available for multiple beam-spread options
Control
  • Input method DMX512 via 5-pin XLR
  • Protocols DMX512/RDM
  • RDM configuration
  • UI type LCD
  • Local control
  • Onboard presets
  • Onboard sequences
  • Fixture-to-fixture control
  • Notes 15-bit virtual dimming engine
Electrical
  • Voltage range 100–240 VAC 50/60 Hz
  • Input method Neutrik powerCON in and thru. Requires power from non-dim source
  • Inrush (first half-cycle) 15 A at 120 V, 40 A at 240 V
  • Fixtures per circuit 10 (15 A via power thru)*
  • Wattage (typical) 104
  • Current draw 0.88 A at 120 V, 0.42 A at 240 V
 *Note: All measurements are for 120 V, 60 Hz. Results may vary in different regions.
Thermal
  • Ambient operating temp -20°–40°C (-4°–104°F)
  • Droop compensation
  • BTUs/hour 375.32
Physical
  • Materials Die-cast, all metal housing, Black
  • Yoke Mounting
  • IP rating IP20
  • Weight 6.4 kg (14 lb)
Notes Easy access slots for secondary lenses and standard 7.5 inch PAR acessories
Regulatory and Compliance
  • Approved regulatory standards: UL 1573, CSA C22.2 No. 166, CE Compliant, EAC Compliant
