ETCpad Integrated System Series
$1,374.00
SKU:
4250A1222
Condition:
Used
Availability:
Previously used unit
GENERAL INFORMATION
Control and configuration apps have become an integral part of modern lighting control systems. Unlike consumer tablets, ETCpad is designed specifically as an accessory for your ETC lighting system.  Rather than depending on an internet connection and an individual’s store account, apps are loaded and updated via ETC’s update utility software: UpdaterAtor.
ETCpad can connect to your lighting system wirelessly, but for
mission critical situations, ETCpad offers a built-in RJ45 connector, for direct communication with your network.
Big spaces require big control. Technical staff at your facility can use a fleet of ETCpad tablets to configure and control connected systems. Accessories like the ETCpad multi-tablet charger provides a central housing location for your facility to charge and store your devices.
For drawings, photos, and more, visit the ETCpad product webpage
HARDWARE AND INTERFACES
  • Ruggedized exterior with rubber edges for use in demanding environments
  • Embedded Android environment, locked down to only launch supported mobile applications (listed below), no store account needed
  • 8” full HD display with scratch-resistant glass and multi-touch control
  • Rechargeable lithium-ion battery (3.8 V, 4900 mAh, 18.62 Wh), providing up to 12 hours of operation under normal conditions
  • One 802.11ac WiFi Ethernet adapter
  • Bluetooth 5.0 for connecting with supported products
  • Removable wired network adapter plate, with hand-grip, one configurable Gigabit Ethernet port (RJ45 connector), management clip for cable up to 6mm in diameter
  • One USB-C 3.1 port, for charging and applying updates
  • One Micro SD slot, for applying updates
  • One POGO expansion connector, for use with available docks and chargers
  • Power switch
  • Power/battery status indicator
ELECTRICAL AND THERMAL
  • Power consumption approximately 3 A at 5 V or 2 A at 9 V
  • Ambient room temperature -10°C to 50°C (14°F to 122°F)
SUPPORTED MOBILE APPLICATIONS & COMPATIBILITY
  • Eos Focus Remote - works with Eos Family entertainment controllers including: Eos Ti, Gio, Gio @5, Ion Xe 20, Ion Xe, Element 2, Eos RPU3, Ion Xe RPU, ETCnomad & Eos for Windows/macOS
  • EchoAccess - works with Echo architectural control systems that include an Echo Expansion Bridge
  • Paradigm Touchscreen Remote - works with Paradigm architectural control Systems that include 7” touchscreens
  • Paradigm Mobile Button Station - works with Paradigm architectural control systems
  • MyETC: Photometrics - app containing useful data on ETC luminaires
  • Sensor3 TPSR - works with Sensor3 power control systems
 REGULATORY AND COMPLIANCE
  • CE compliant
  • CULus listed
  • FCC compliant
  • RoHS compliant
  • WEEE
  • IP-65 rated enclosure
