FIXTURE SOLAFRAME THEATRE
$5,128.50
SKU:
H7010030-UB
Condition:
Used
Availability:
Usually ships in 7-10 business days. Expedited shipping options are not available through the website. For faster shipping methods or deliveries to international locations, Alaska, Hawaii, or U.S. Outlying Territories, please contact Customer Service
Previously used unit
Includes 90-day warranty - if the used item fails within this period, it may be returned for a refund or a warranty repair.
FIXTURE OVERVIEW
SolaFrame Theatre is a fanless, convection-cooled automated luminaire that prioritizes high quality features, spectral output and silence. When you need an automated lighting product that is audibly invisible and visually impactful, the SolaFrame Theatre is the right choice. With a feature set designed for exquisite projection control and beautiful color rendering, SolaFrame Theatre can quietly steal the scene.
Applications
  • Theatres of all sizes
  • Concert halls
  • Opera houses
  • Film and television broadcast studios
  • Churches and houses of worship
Product Features
  • Bright white LED engine
  • 440 W High CRI engine producing 16,200 max lumens
  • High quality 13-lens optic system with patented Lens Defogger
  • Versatile 7°–42° zoom
  • CMY/CTO-Linear color mixing system
  • Seven position plus open replaceable Color Wheel
  • Full-curtain framing system for total control of beam shaping
  • 16-blade iris for extremely tight beam effects
  • Smooth variable light diffusion
  • Seven position plus open Rotating Gobo Wheel
  • Eight position plus open interchangeable Fixed Gobo Wheel
  • Linear rotating prism for controlled pattern replication across a stage
PRODUCT SPECIFICATIONS
Source
  • Engine High CRI Engine
  • LED Details 440 W
  • Max Field Lumens 15,000 Lumens
  • Integrating Sphere Lumens 16,200 Lumens
  • LPW 37
  • LED Life 50,000 hours
  • Native CCT 6,000 K
  • Transferable Light Engine
Color
  • Color Mixing Cyan, magenta, yellow, CTO-linear
  • Color Temperature Variable down to 2,800 K
  • Color Wheel Seven (7) interchangeable dichroic chips plus open
Optical
  • Beam Angle Range 7°–42°
  • Gate Size 28 mm
  • Pattern Projection
  • Rotating wheel with seven (7) patterns plus open
  • Interchangeable fixed position wheel with eight (8) patterns plus open
  • Animation Rotating animation wheel
  • Prism Linear 4 facet
  • Frost Light frost
  • Iris 16-blade iris
  • Framing Four-plane, full-curtain framing system with 90° module rotation
  • Flicker Control/Hz Range 100 Hz, 2.4 kHz, or 16 kHz
Control
  • Input Method DMX (5-pin) or Ethernet with passive thru
  • Protocols DMX via RS-485, Art-Net or sACN via Ethernet
  • Ethernet Pass-Thru Passive Ethernet in and thru with and without power
  • Data Conversion: Patented data conversion system for: DMX to Ethernet, Ethernet to DMX
  • Modes (Footprint) One (47 channels)
  • RDM Functions
  • UI Type Full color graphical UI with 6-button navigational control
  • Local Control
  • Dimming Performance 16-bit, DMX controlled
Electrical
  • Voltage Range 100–240 V, 50–60 Hz
  • Input Method powerCON TRUE1
  • Wattage (Standard/+Defogger) 703 W / 738 W
  • Current (Max) 7.5 A @ 100 V / 3.0 A @ 240 V
  • Inrush (first half-cycle) 120 V: 22.6 A 208 V: 33.4 A
Thermal
  • Ambient Operating Temp 0°–35°C (32°–95°F)
  • Fan Mode Fanless, Convection-cooled
  • Stationary Noise 28 dBA at full intensity (17.8 dBA background noise)
  • Lens Defogging Patented Lens Defogger included
Physical
  • Pan and Tilt Range 540° pan, 265° tilt
  • Max Pan/Tilt Speed 360° in 2.9 s / 180° in 1.96 s
  • Materials Steel and aluminum frame with molded plastic covers
  • Color Black
  • Mounting Options Any orientation
  • IP Rating IP-20
  • Weight 50.35 kg (111 lb)
  • Included Accessories: powerCON TRUE1 to bare end fixture tail, Two (2) 180 mm Single-hole Omega brackets, Safety Cable
Regulatory & Compliance
  • Regulatory Standards: Listed to UL 1573, Certified to CSA STD. C22.2 No: 166, EAC,
  • CE compliance declared to these standards: Safety: EN 60598-1, EN 60598-2-17, EN 62031, EN 62471 EMC: EN 55015, EN 61547, EN 61000-3-2, EN 6100-3-3
  • Complies to the ROHS directive
Safety
  • Minimum distance to illuminated surface = 2.0 m (6.5 ft)
  • Minimum distance from fixture head to combustible materials = 0.5 m (1.6 ft)
Notes: All LED sources experience some lessening of light output and some color shift over time. LED output will vary with thermal conditions. Thermal conditions can be affected by ambient temperatures and orientation.
