Previously used unit
FIXTURE OVERVIEW
Lightweight and compact, the SolaSpot 1000 offers high intensity output and a full feature set for complete creative freedom. Designed for mid-size applications, SolaSpot 1000 is perfect for houses of worship, live productions, cruise ships and special events. A 440-watt Ultra-Bright White LED engine and specially designed optics produce 18,000 lumens, allowing the fixture to boldly shine through the crowd, while the cutting edge rotating Animation wheel, fixed gobo and color wheels, CMY/CTO system, iris, frost, prism, and 11 to 48 degree zoom create a cornucopia of lighting effects. The fixture includes many other exclusive patented technologies such as Active Thermal Control and our Lens Defog System.
APPLICATIONS
- Concert venues
- Film and television broadcast studios
- Churches and houses of worship
PRODUCT FEATURES
- Ultra-Bright white LED engine
- 440 W engine producing 18,000 field lumens
- High quality optic system with patented Lens Defogger
- Versatile 11°–48° zoom
- CMY/CTO-Linear color mixing system
- Seven position plus open replaceable Color Wheel
- 16-blade iris for extremely tight beam effects
- Light diffusion
- Six position plus open Rotating Gobo Wheel and seven position plus open fixed gobo wheel
- Linear rotating prism for controlled pattern replication across a stage
- Rotating Animation wheel with bi-directional control
- LED Animation control
- Patented Lens Defogger
- ArtNet, DMX, and sACN control with patented internal data conversion
SOURCE
- Engine Ultra-Bright White LED
- LED Details 440 W
- Integrating Sphere Lumens 18,000 lumens
- LPW 40.9
- LED Life 50,000 hours
- Native CCT 7000 K
- Transferable Light Engine
COLOR
- Color Mixing Cyan, magenta, yellow, CTO-linear
- Color Temperature Variable down to 2800 K
- Color Wheel Seven (7) interchangeable dichroic chips plus open
OPTICAL
- Beam Angle Range 11°–48°
- Gate Size 28 mm
- Pattern Projection
- Rotating and indexable wheel with six (6) interchangeable patterns plus open Fixed gobo wheel with seven (7) interchangeable patterns plus open
- Animation Bi-directional animation wheel LED animation
- Prism Four facet linear rotating prism
- Frost Light diffusion
- Iris 16-blade iris
- Flicker Control/Hz Range 2.4 kHz
CONTROL
- Input Method DMX (5-pin) or Ethernet
- Protocols DMX via RS-485, Art-Net or sACN via Ethernet
- Ethernet Pass-Thru Passive Ethernet in and thru with and without power
- Data Conversion Patented data conversion system for:
- DMX to Ethernet
- Ethernet to DMX
- Modes (Footprint) Standard (48 channels) and Reduced (28 channels)
- RDM Functions
- UI Type Full color graphical UI with 6-button navigational control
- Local Control
- Dimming Performance 16-bit, DMX controlled
ELECTRICAL
- Voltage Range 100–240 VAC, 50–60 Hz
- Input Method powerCON TRUE1
- Wattage (Standard/+Defogger) 750 W / 785 W
- Current (Max) 7.9 A @ 100 V
THERMAL
- Ambient Operating Temp 0°–45°C (32°–113°F)
- Fan Mode Three Modes: Standard, Continuous, Studio
- Stationary Noise 38 dBA at full intensity (32 dBA background noise)
- Lens Defogging Patented Lens Defogger included
PHYSICAL
- Pan and Tilt Range 540° pan, 265° tilt
- Max Pan/Tilt Speed 360° in 2.42 s / 180° in 1.46 s
- Materials Steel and aluminum frame with molded plastic covers
- Color Options Black, white by request
- Mounting Options Any orientation
- IP Rating IP20
- Weight 28.6 kg (63 lb)
- Included Accessories powerCON TRUE1 to bare end fixture tail, Two (2) clamp brackets, Safety cable
