Previously used unit
GENERAL INFORMATION
ETC, the market leader in automated luminaire innovation, brings you the next generation hallmark of white light Framing fixtures. High End Systems Halcyon Platinum, the flagship product in the Halcyon Framing family of fixtures, has 54,000 lumens of output and a boost mode with over 70,000 lumens of output in a 99 lb frame. Outperforming fixtures of the past by as much as 20,000 lumens, Halcyon Platinum also has an extreme feature set with everything a user needs to light shows of all shapes and sizes.
Applications
- Houses of worship
- Arenas and stadiums
- Medium to large-sized performance venues
- Cruise ships and themed entertainment
- Production rental companies
- Trade show and ballroom AV
- Film
Product Features
- Bright white LED engine
- 1200 W LED engine
- Standard mode output exceeds 54,000 lumens
- Boost mode exceeding 70,000 lumens
- High quality 13-lens optic system
- Extremely powerful 6°–64° zoom
- Optimized CMY and CTO color mixing for even hue control
- Six position plus open color wheel
- Full-curtain framing system for total control of beam shaping
- 16-blade iris for extremely tight beam effects
- Trifusion frost system with linear insertion from light to heavy and everything in between
- Two, 7 position plus open Rotating Gobo Wheels
- Dual prisms for compound beam and projection effects
- Rotating Animation Wheel with linear positioning and angular control
- Patented Whisper Home technology for quiet pan and tilt calibration/homing at boot with minimal movement
GENERAL INFORMATION
Source
- Engine Ultra-Bright
- LED Details 1200 W Hot-Spot Engine
- Max Integrating Sphere Lumens 54,000 lm (standard) 70,000 lm (boost)
- LPW 45
- LED Life 50,000 hours
- Native CCT 6500 K
Color
- Color Mixing Cyan, magenta, yellow, CTO
- Color Temperature Variable down to 2200 K
- Color Wheel Six (6) dichroic colors plus open
Optical
- Beam Angle Range 6°–64°
- Gate Size 30 mm
- Aperture Size 180 mm
- Pattern Projection: Two rotating and indexable wheels with seven (7) interchangeable patterns plus open on each
- Animation: Bi-directional rotating animation wheel with linear insertion, and variable angle, - LED Animation
- Prism: Five-facet star and four-facet linear rotating prism with simultaneous insertion
- Diffusion: Light, Medium, and Heavy frost seamlessly controlled with Trifusion control.
- Iris: 16-blade iris
- Framing: Four-plane, full-curtain framing system with 180° module rotation
- Flicker Control/Hz Range: 2.4 kHz and 16 kHz
Control
- Input Method DMX (5-pin) or Ethernet
- Protocols: DMX via RS-485, Art-Net or sACN via Ethernet
- Ethernet Pass-Thru: Passive Ethernet in and thru with and without power
- Data Conversion: Patented data conversion system for Ethernet to DMX
- Modes (Footprint): Standard (60 channels)
- RDM Function
- UI Type: Full-color graphical UI with touch screen and 5-button navigational control, NFC Configuration
- Local Control
- Dimming Performance: 16-bit, DMX controlled
Electrical
- Voltage Range 120–240 V 50–60 Hz
- Input Method powerCON TRUE1 TOP
- Wattage (Standard/Boost/Max/Standby) 1332 W / 1707 W / 1820 W / 39 W
- Current (Max) 15.3 A @ 120 V
- Inrush (First Half Cycle) 120 V: 69 A, 230 V: 91 A
- Fixtures per Circuit: 1 fixture (R20 module or similar) Note: TRUE1 TOP connector rated for
- 20 A (120 V / 60 Hz) and 16 A (240 V / 50 Hz)
Thermal
- Ambient Operating Temp -10°–40°C (14°–104°F)
- Fan Mode Standard, Studio, and Linear Continuous control channel
Physical
- Pan and Tilt Range 540° pan, 261° tilt
- Max Pan/Tilt Speed 360° in 2.83 s / 180° in 1.97 s
- Encoders: Whisper Home, absolute encoders
- Materials Steel and aluminum frame with molded plastic covers
- Color Black
- Mounting Options Any orientation
- IP Rating IP20
- Weight 45 kg (99 lb)
- Included Accessories: powerCON TRUE1 TOP to bare end fixture tail Two (2) 180 mm Three-hole Omega brackets, Safety cable
Regulatory & Compliance
- Approved regulatory standards: cETLus Listed, Listed to UL 1573, Certified to CSA STD. C22.2 No: 166
- CE Compliant, UKCA Compliant
- Complies to the ROHS directive
Safety
- Minimum distance to illuminated surface = 4.0 m (13.1 ft)
- Minimum distance from fixture head to combustible materials = 0.1 m (4.0 in)
Notes: All LED sources experience some lessening of light output and some color shift over time. LED output will vary with thermal conditions. Thermal conditions can be affected by ambient temperatures and orientation.
