Previously used unit
ETC, the market leader in automated luminaire innovation, brings you the next generation hallmark of white light framing fixtures. High End Systems Halcyon Titanium, the middle product in the Halcyon Framing family of fixtures, is an earth shattering luminaire with over 40,000 lumens of output in a 76 lb frame. Outperforming fixtures of the past by 15,000 lumens and 20 lb, Halcyon Titanium also has an extreme feature set with everything a user needs to light shows of all shapes and sizes.
Applications
- Houses of worship
- Small to medium-sized performance venues
- Cruise ships and themed entertainment
- Production rental companies
- Trade show and ballroom AV
- Studio and film
Product Features
- Bright white LED engine
- 600 W Ultra-Bright engine
- Fixture output exceeding 40,000 lumens
- High quality 13-lens optic system
- Extremely powerful 6°–60° zoom
- Optimized CMY and CTO color mixing for even hue control
- Six position plus open color wheel
- Full-curtain framing system for total control of beam shaping
- 16-blade iris for extremely tight beam effects
- Trifusion frost system with linear insertion from light to heavy and everything in between
- Two, 7 position plus open Rotating Gobo Wheels
- Dual prisms for compound beam and projection effects
- Rotating Animation Wheel with linear positioning and angular control
- Patented Whisper Home technology for quiet pan and tilt calibration/homing at boot with minimal movement
Source
- Engine - High Fidelity
- LED Details 600 W
- Max Integrating Sphere Lumens 24,000
- LPW 40
- LED Life 50,000 hours
- Native CCT 5800 K
Color
- Color Mixing Cyan, magenta, yellow, CTO
- Color Temperature Variable down to 2200 K
- Color Wheel Six (6) dichroic colors plus open
Optical
- Beam Angle Range 6°–60°
- Gate Size 26 mm
- Aperture Size 144 mm
- Pattern Projection
- Two rotating and indexable wheels with seven (7) interchangeable patterns plus open on each
- Animation
- Bi-directional rotating animation wheel with linear insertion, and variable angle
- LED Animation
- Prism Five facet star and four facet linear rotating prism with simultaneous insertion
- Diffusion Light, Medium, and Heavy frost seamlessly controlled with Trifusion control.
- Iris 16-blade iris
- Framing Four-plane, full-curtain framing system with 180° module rotation
- Flicker Control/Hz Range 2.4 kHz and 16 kHz
Control
- Input Method DMX (5-pin) or Ethernet
- Protocols
- DMX via RS-485
- Art-Net or sACN via Ethernet
- Ethernet Pass-Thru Passive Ethernet in and thru with and without power
- Data Conversion Patented data conversion system for Ethernet to DMX
- Modes (Footprint) Standard (60 channels)
- RDM Functions
- UI Type
- Full-color graphical UI with touch screen and 5-button navigational control
- NFC Configuration
- Local Control
- Dimming Performance 16-bit, DMX controlled
Electrical
- Voltage Range 100–240 V 50–60 Hz
- Input Method powerCON TRUE1 TOP
- Wattage (Standard/Max/Standby) 960 W / 1126 W / 31 W
- Current (Max) 11.3 A @ 100 V
- Inrush (First Half Cycle)
- 120 V: 69 A
- 230 V: 123 A
- Fixtures per Circuit
- 1 fixture (R20 module or similar)
- Note: TRUE1 TOP connector rated for
- 20 A (120 V / 60 Hz) and
- 16 A (240 V / 50 Hz)
Thermal
- Ambient Operating Temp -10°–40°C (14°–104°F)
- Fan Mode Standard, Studio, and Linear Continuous
- control channel
Physical
- Pan and Tilt Range 542° pan, 258° tilt
- Max Pan/Tilt Speed 360° in 2.54 s / 180° in 1.67 s
- Encoders Whisper Home, absolute encoders
- Materials Steel and aluminum frame with molded plastic covers
- Color Options Black, white by request
- Mounting Options Any orientation
- IP Rating IP20
- Weight 34.5 kg (76 lb)
- Included Accessories
- powerCON TRUE1 TOP to bare end fixture tail
- Two (2) 180 mm Three-hole Omega brackets
- Safety cable
