Previously used unit
GENERAL INFORMATION
The High End Systems Lonestar brings the renowned brightness, quality, and performance of our bright white LED framing fixtures in a more compact package. With more than 15,400 lumens and a rich feature set, Lonestar is a perfect addition to lighting systems in theatres, television studios, cruiseships, and other small to medium-sized venues. The luminaire’s rich colors, powerful zoom, full curtain framing, diffusion, and prism effects make Lonestar a versatile and affordable tool for designers who want maximum performance from a compact-sized automated fixture.
Applications
- Houses of worship
- Nightclubs and retail installations
- Small to medium-sized performance venues
- Cruiseships and themed entertainment
- Production rental companies
- Tradeshow and ballroom AV
- Studio and film
Product Features
- Bright white LED engine
- 290 W Ultra-Bright engine
- Fixture output 15,400 lumens
- High quality 13-lens optic system
- Extremely powerful 3.8°–55° zoom
- CMY color mixing system
- Electronic linear CCT mixing control
- Ten position plus open color wheel
- Full-curtain framing system for total control of beam shaping
- 15-blade iris for extremely tight beam effects
- Two diffusion Light and Medium system with additional,
- optional heavy diffusion
- Nine position plus open Rotating Gobo Wheel
- Dual prisms for compound beam and projection effects
- Linearly insertable rotating animation wheel
Source
- Engine Ultra-Bright
- LED Details 290 W
- Integrating Sphere Lumens 15,400 lumens
- LPW 53
- LED Life 50,000 hours
- Native CCT 7000 K
Color
- Color Mixing Cyan, magenta, yellow, CTO-linear
- Color Temperature Variable down to 2200 K
- Color Wheel Ten (10) dichroic colors plus open
Optical
- Beam Angle Range 3.8°–55°
- Gate Size 15.8 mm
- Aperture Size 120 mm
- Pattern Projection Rotating and indexable wheel with nine (9) patterns plus open
- Animation Bi-directional animation wheel
- Prism Five facet star and four facet linear rotating prism with simultaneous insertion
- Diffusion Light and medium diffusion Optional heavy diffusion in prism slot
- Iris 15-blade iris
- Framing Four-plane, full-curtain framing system with 120° module rotation
- Flicker Control/Hz Range 2.4 kHz and 16 kHz
Control
- Input Method DMX (5-pin) or Ethernet
- Protocols DMX via RS-485 Art-Net or sACN via Ethernet
- Ethernet Pass-Thru Passive Ethernet in and thru with and without power
- Data Conversion Patented data conversion system for: DMX to Ethernet, Ethernet to DMX
- Modes (Footprint) Standard or Trifusion (48 channels)
- RDM Functions
- UI Type Full color graphical UI with 6-button navigational control
- Local Control
- Dimming Performance 16-bit, DMX controlled
Notes: All LED sources experience some lessening of light output and some color shift over time. LED output will vary with thermal conditions. Thermal conditions can be affected by ambient temperatures and orientation
Electrical
- Voltage Range 100–240 V 50–60 Hz
- Input Method powerCON TRUE1 TOP
- Wattage (Max) 615 W
- Current (Max) 6.2 A @ 100 V
- Inrush (First Half Cycle) 120 V: 56.8 A 230 V: 78.0 A
- Fixtures per Circuit 2 fixtures (15 A power thru connector), 3 fixtures (R20 module or similar)
- Note: TRUE1 TOP connector rated for 20 A (120 V / 60 Hz) and 16 A (240 V / 50 Hz)
Thermal
- Ambient Operating Temp -10°–40°C (14°–104°F)
- Fan Mode Standard, Studio, and Linear Continuous control channel
- Stationary Noise 35 dBA at full intensity (16.3 dBA background noise)
Physical
- Pan and Tilt Range 540° pan, 251° tilt
- Max Pan/Tilt Speed 360° in 2.306 s/180° in 1.26 s
- Materials Steel and aluminum frame with molded plastic covers
- Color Black
- Mounting Options Any orientation
- IP Rating IP20
- Weight 23 kg (50 lb)
Included Accessories
- powerCON TRUE1 TOP to bare end fixture tail, Two (2) 107 mm Three-hole Omega clamp brackets, Safety cable
Regulatory & Compliance
- Regulatory Standards Listed to UL 1573, Certified to CSA STD. C22.2 No: 166, FCC Class A, EAC,
- CE compliance declared to these standards, Safety: EN 60598-1, EN 60598-2-17, EN 62031, EN 62471
- EMC: EN 55015, EN 61547, EN 61000-3-2, EN 61000-3-3
- Complies to the ROHS directive
Safety
- Minimum distance to illuminated surface = 3.0 m (10 ft)
- Minimum distance from fixture head to combustible materials = 0.1 m (4.0 in)
