PARADIGM ARCHITECTURAL CNTRL PROCESSOR 3
$1,492.00
SKU:
7180A1029
Availability:
Previously used unit
GENERAL INFORMATION
The Paradigm Architectural Control Processor is designed for easy interaction and rapid response. The Paradigm ACP’s built-in memory and processing power works with vast amounts of lighting control data and is fast enough to process 1,024 simultaneous fades over any of its native protocols.
APPLICATIONS
  • Houses of worship
  • Schools
  • Restaurants
  • Hotels
  • Museums
  • Casinos
  • Ballrooms
FEATURES
  • Designed for use in Unison DRd and ERn enclosures
  • Point of Control Interface: easy-to-read system display shows the user pertinent system information
  • Supports Calculated Energy Reporting for configured loads when used in a Central Control Server System.
  • when used in a Central Control Server System.
  • LinkConnect: using Echelon® LonTalk® protocol with LinkPower, the two-wire topology-free system gives you the freedom to put stations where you need them
  • NetConnect: Makes use of low-cost, easy-to-install Cat5/5e with PoE to connect touchscreen stations and other devices to a networked Paradigm System
  • USBConnect: support for USB flashdrives for configuration upload and download
  • QuickLoad: SD Media support for upload, and backup of configuration data
  • LightDesigner Access: Web browser interface for easy modification, activation and monitoring of your system configuration and status.
  • LocalAccess: user control at the interface, including creation of timed events and editing of presets or sequences
  • Secure-It Access Control: multiple levels of secure user access at the interface
REGULATORY AND COMPLIANCE
  • cULus Listed
  • CE Compliant
