PEARL CE SL3 LED FIXTURE 21
$1,537.00
SKU:
7401A1102
Availability:
Previously used unit
Pearl CE SL3 21" LED Fixture
GENERAL INFORMATION
The Selador Series Pearl CE fixture uses the power of white LEDs to provide a highly efficient tool for video and event production. A carefully chosen array of 3200°K warm white LEDs and 5700°K cool white LEDs allow the user to create the appropriate white light needed for any on-camera or general area lighting situation where high-intensity white light fills the need. The mix of warm and cool white LEDs provides tunable white light that is maximized for brightness across a broad Correlated Colour Temperature (CCT) range. Selador’s unmatched system of horizontal and vertical spread lenses lets you create the field size you need in any situation.
No Accessories or Lensing included.
APPLICATIONS
  • Video lighting
  • Press events
  • Location lighting
  • General area lighting
GENERAL
  • 40 x 2.5W adjustable-white LED fixture
  • Available in 11, 21, 42, and 63 lengths
  • IP20 rated for indoor dry location use
PHYSICAL
  • Rugged all-metal extruded housing
  • Advanced thermal management systems for long LED life
  • Easy-access slots for secondary lenses
  • Combine secondary lenses for desired horizontal and vertical beam spread
  • Available in black (standard) and silver (special order)
  • Single and double yoke (11 and 21 only), trunnion (floor stand), and hanging bracket mounting options
ELECTRICAL
  • 100VAC to 240V 50/60 Hz universal power input
  • Neutrik PowerCon input connector
  • 1. 5m power lead (PowerCon to bare end pigtail) supplied
  • Requires power from non-dim source
  • Low-speed, low-noise temperature controlled cooling fan for thermal stability
LED
  • 50,000 hr. LED life
  • 40 Luxeon® Rebel 2.5W LED emitters per cell
COLOUR
  • Pearl – optimized for brightest white light with variable warm and cool-white LEDs for colour temperature adjustment.
  • Color rendering as high as 90 CRI
  • Interacts seamlessly with conventional sources
  • Ideal for studio, video, and location work where high brightness white light with low power consumption is desired
OPTICAL
  • Native tight field angle of 17°
  • Secondary lenses install in fixture front to change distribution of light
  • Use a combination of vertical and horizontal lenses to spread light both directions
  • Lenses must be ordered separately (See accessory list)
CONTROL
  • DMX512 in and thru via 5-pin XLR connectors
  • 3 channel control: Warm White, Cool White, Master Intensity
  • Intensity channel maintains constant colour temperature during dimming
  • 15-bit internal control for smooth low-end dimming
  • 21 fixture provides 2 independently controlled cells
THERMAL
  • Ambient operating temperature of 0°C- 43°C
  • Fixture case can become extremely hot (approx. 85°C) under long-term, high-output, continuous usage
  • Fixture is designed for continuous usage at 40°C ambient temperature. Requires free air flow around fixture.
  • Fan speed thermostatically controlled for no noise operation except when required.
