Previously used unit
Pearl SL3 42" LED Fixture
GENERAL INFORMATION
Selador Classic™ Pearl uses the power of white LEDs to provide a highly efficient fixture for video and event production. a carefully chosen array of 3200K warm-white LEDs and 5600K cool-white LEDs allows the user to create the appropriate high-intensity white light needed for any on-camera or general-area lighting situation. the mix of warm- and cool-white LEDs provides tunable white light that is maximized for brightness across a broad CCT range. Selador’s unmatched system of horizontal and vertical spread lenses lets you create the field size you need for any application.
No accessories or lensing included.
APPLICATIONS
- Broadcast lighting
- Press events
- Location lighting
- General area lighting
FEATURES
- 40 x 2.5W adjustable-white LED luminaire
- available in 11”, 21”, 42”, and 63” lengths
- ETL rated for indoor, dry-location use
PHYSICAL
- rugged all-metal extruded housing
- advanced thermal management systems for long LED life
- easy-access slots for secondary lenses
- Combine secondary lenses for desired horizontal and vertical beam spread
- available in black (standard) and silver (special order)
- Yoke (11” and 21” only), trunnion (floor stand), and hanging bracket mounting options
ELECTRICAL
- 100VaC to 240V 50/60Hz universal power input
- Neutrik® PowerCon™ input connector
- 5’ power lead (parallel-blade, U-ground) supplied (see page 1 for input connector options)
- Requires power from non-dim source
- Low-speed, low-noise cooling fan for thermal stability LED
- 50,000-hour LED life
- 40 Luxeon® rebel 2.5W LED emitters per cell
COLOR
- Optimized for the brightest white light with variable warm-and cool-white LEDs for color temperature adjustments
- Color rendering as high as 90 Cri
- Interacts seamlessly with conventional sources
- Ideal for studio, video, and location work where high-brightness white light with low power consumption is desired.
OPTICAL
- Native tight field angle of 17°
- Secondary lenses install in the front of the fixture to change distribution of light
- Use a combination of vertical and horizontal lenses to spread light in both directions
- Lenses must be ordered separately
- Refer to accessories for lenses available
CONTROL
- DmX512 in and thru via five-pin XLR connectors
- Three-channel control: Warm White, Cool White, master intensity
- Intensity channel maintains a constant color temperature during dimming
- 42” fixture provides four independently controlled cells
THERMAL
- Ambient operating temperature of 32° to 104°f (0° to 43°C)
- Fixture case can become extremely hot (approx. 85°C) under long-term, high-output, continuous usage
- Fixture is designed for continuous usage at 40°C ambient temperature. requires free air flow around fixture
