Previously used unit
GENERAL INFORMATION
The ETC Response Opto-Splitter provides quality and reliable DMX data distribution. Using industry-standard DMX and RDM, the Response Opto-Splitter unlocks the power of your DMX system.
FEATURES
- Multi-port DMX splitter with DMX-in and DMX-thru
- Optically isolated DMX512 ports
- Supports Remote Device Management (RDM) Protocol
- DIN rail and rack-mount versions
- Power and DMX presence status indicators
- Supports update of connected ETC fixtures
- DIN enclosures variants available for UL 924 Emergency
- Control Bypass applications
APPLICATIONS
- Road houses and touring
- University/professional theatres
- Hotels and Convention halls
- System integration
- Houses of worship
- House lighting
- Museums
- Themed environments
FUNCTIONAL
- No configuration required
- Supports DMX512, DMX512 (1990), and DMX512-A
- Supports ANSI E1.20 Remote Device Management (RDM)
- Supports up to 256 total RDM devices
MECHANICAL
- Rack-mount form factor:
- - Fabricated from aluminum
- - Black, Fine-textured, powder-coat finish
- - Full 19 in equipment rack width
- - Front or rear facing mounting options
- DIN rail form factor:
- - Molded plastic enclosure
- - Mounting complies with DIN43880 (35/7.5 rail)
- - Unit is nine DIN units wide
- - DIN installation enclosure available
- Power and data activity LED indicators
- - Blue power indicator
- - Green DMX activity indicator
ELECTRICAL
- Supports DMX input and DMX thru
- Provides optically isolated DMX/RDM outputs
- 100–240 VAC 50/60 Hz power input
- User configurable front or rear IEC C13 power connector position
- 35 W max power draw
- XLR, RJ45 and Terminal connector options
- 12–48 VDC power input
- 8 W max power draw
- Wiring connections use plugable terminals
- Clamp style connectors for solid and stranded cable wiring provided for terminal versions
- DIN box form factors include a suitable power supply. For more details on using this power supply with other products please contact ETC’s Application Engineering Department
ENVIRONMENTAL
- Ambient operating temperature: -10°C–65°C (14°F–149°F)
- Operating humidity: 5–95% non-condensing
- Storage temperature: -40°C–70°C (-40°F–158°F)
REGULATORY AND COMPLIANCE
- cETLus Listed
- cETLus Listed to UL 924 (Emergency DIN Boxes Only)
- CE compliant
- RoHS compliant
- WEEE
