S4 LED Cyc Lens Tube (White)
$110.00
SKU:
7460A2011-1
Condition:
New
Availability:
NEW Unit
Standard ETC Warranty for this product applies.
GENERAL INFORMATION
The Source Four LED CYC adapter brings the infinite color options of the x7 Color System to your cyc. Using ETC’s innovative design, you can quickly turn your Source Four LED or ColorSource Spot into a bright, colorful and versatile cyclorama wash light. With its simple setup, you can easily achieve beautiful cyc-light distribution from the same Source Four LED or ColorSource Spot light engine you already have.
PHYSICAL
  • Rugged, die-cast, aluminum construction
  • Fits all standard Source Four LED or ColorSource Spot light engines
    • *Not for use with HPL Source Four fixtures*
  • Compatible with ETL and CE fixtures
  • Can be top- and/or bottom-mounted
  • Simple, flexible setup
OPTICAL
  • Bright, even wash light
  • Maximum color control with ETC’s x7 Color System
  • Smooth coverage up to 40 ft (top and bottom lit)
  • Efficient 2:1 spacing ratio (maximum) from cyc
    • 1.5:1 ideal spacing ratio
  • Heat- and impact-resistant polycarbonate lenses
