S4 LED FRESNEL ADAPTER
$326.00
SKU:
7460A2016
Condition:
Used
Availability:
Previously used unit
Includes 90-day warranty - if the used item fails within this period, it may be returned for a refund or a warranty repair.
GENERAL INFORMATION
The Source Four LED Fresnel adapter uses all the power and beauty of the Source Four LED light engine to create an astounding beam light suitable for any stage or studio. With ETC’s unique interface, you can quickly turn your Source Four LED or ColorSource Spot into a powerful, controllable Fresnel. With the addition of this accessory, your Source Four LED will always be the right fixture for the job.
PHYSICAL
  • Rugged, die-cast, aluminum construction
  • Compatible with all Source Four LED and ColorSource Spot engines - *Not for use with HPL Source Four fixtures*
  • Compatible with ETL and CE fixtures
  • Quick and easy operation
  • Compact optics
  • Single-handed accessory-slot access
  • Simple setup
  • Available in black and white
OPTICAL
  • Bright, smooth washlight
  • 15-50 degree zoom
  • Barn-door beam shaping
  • Heat- and impact-resistant polycarbonate lenses
