S4LEDSER2 TUN HD ETL LTENG W/ BARL BLK
$752.00
SKU:
7461A1061
Availability:
Previously used unit
Includes 90-day warranty - if the used item fails within this period, it may be returned for a refund or a warranty repair.
GENERAL INFORMATION
The Source Four LED Series 2 is the evolution of LED lighting. While it may look the same on the outside, the Series 2 offers even more of what makes the Source Four LED the best LED profile available. With optimized arrays and finely-tuned electronics, the Series 2 offers a combination of light quality and output that cannot be matched.
Source Four LED Series 2 Tungsten HD array is designed for broadcast lighting, offering flicker-free operation and high-definition lighting. With a new mix of LED emitters, the luminaires’ output is significantly brighter than the original Source Four LED white-light arrays. The Tungsten HD array matches conventional tungsten lighting, with adjustable warm-white (2700 to 4500K) light. They offer tint control, so they can be tweaked to perfectly illuminate individual skin tones.
Series 2 light engines work with all Source Four lens tubes to deliver a high-quality, controllable beam of LED light. For the best results, it is highly recommended that EDLT versions are used. We also offer a special LED-only version of the 50° lens tube.
Does NOT include Lens Tube.
GENERAL
  • 60-LED array
  • ETL listed to UL1573 – the standard for stage and studio lighting units
  • IP20-rated for indoor use
  • Power and DMX in/thru connections for easy setup
  • User-friendly control interface with multiple modes and fixture settings
PHYSICAL
  • Rugged die-cast all-metal housing
  • Available in black (standard), white or silver gray or custom colors (contact factory)
  • C-clamp
  • Positive-locking double-clutch fixture body
  • Slot for glass or stainless steel patterns and soft-focus diffuser
  • Wide accessory slot with sliding cover for motorized pattern devices or optional iris
  • Hanging yoke standard. Optional yoke/floor-stand available
ELECTRICAL
  • 100VAC to 240VAC 50/60Hz universal power input
  • Neutrik power in and thru connections
  • Up to Tungsten HD luminaires (15A max) may be linked via power thru connector (8 Tungsten HD fixtures total per circuit) when used with R20 Relay Module or Unison® Echo™ Relay Panel
    • Consult breaker-trip curves when used with other equipment. Requires power from a non-dim source
  • Inrush
    • 120V: 50A (First half-cycle)
    • 240V: 107A (First half-cycle)
LED
  • Tungsten HD: 20000-hour LED life (20,000 hours to 70% intensity)
  • 60 Luxeon® Rebel LED emitters
COLOR
  • Selection from the x7 Color System to provide high quality, variable-white light
    • Tungsten HD (2700K-4000K)
  • Beautifully illuminates skin tones and other objects for natural appearance and high color rendering
  • Broad-spectrum color interacts seamlessly with conventional sources
  • Exclusive optional red-shift option emulates tungsten dimming performance
OPTICAL
  • Use the included soft-focus diffuser for creating washes or soft light
  • Best performance using ETC’s EDLT lens tubes
  • Can use all ETC Source Four interchangeable lens barrels: 5°, 10°, 14°, 19°, 26°, 36°, 50°, 70°, and 90° field angles, as well as 19°, 26°, 36°, and 50° EDLT lenses
  • For better performance, use the LED 50° barrel
CONTROL
  • DMX512 in and thru via five-pin XLR connectors
  • Multiple control options, including RGB, strobe, and console-free Master/Slave mode
  • See DMX Control Table for additional information
  • 15-bit virtual dimming engine provides smooth, high-quality theatrical fades and minimizes color shift during dimming
  • RDM functionality for address and setting changes
THERMAL
  • Ambient operating temperature of 32° to 104°F (0° to 40°C)
  • Active electronic thermal management for droop-free operation
  • Quiet fan cooling
  • Fixture is designed for continuous operation up to 104°F (40°C) ambient temperature and requires free flow of air around fixture housing
