S4WRD-COLOR RETROFIT KIT WITH EDISON CONNECTOR BLACK
$352.75
SKU:
7068A1001-A
Condition:
New
Availability:
NEW UNIT
Includes 90-day warranty - if the used item fails within this period, it may be returned for a refund or a warranty repair.
GENERAL INFORMATION
The Source 4WRD Color LED engine transforms your existing Source Four incandescent profile into an RGBA LED fixture, unlocking the world of additive color mixing, saturated washes, and quick color changes. It means more stage looks with fewer fixtures using less energy and needing less maintenance. The simple and quick upgrade is nondestructive and takes less than five minutes. Source 4WRD Color uses switched power, 100–240 VAC, and dims via DMX. And, because it is an LED source, your fixtures will run cool and efficiently without lamp replacements.
APPLICATIONS
  • Energy-saving retrofits
  • Houses of worship
  • Universities and schools
  • Hospitality
  • Retail
  • Exhibition centers
  • Meeting rooms
  • Clubs
  • Theatres
PRODUCT SPECIFICATIONS
Source
  • LED details Nichia LEDs
  • Max lumens (Full On / 3200 K / 5600 K): 4,881 / 3,713 / 4,463
  • Lumens per watt (Full On / 3200 K / 5600 K): 33.9 / 36.8 / 34.3
  • L70 rating (hours to70% output) >60,000 hours*
 *L70 value based on manufacturer’s anticpated results
Color
  • Colors used RGBA (Red, Green, Blue and Amber)
  • Color temperature range 2,200–6,500 K
  • Calibrated array
Optical
  • Field angle range Swappable lens tubes between 5–90 degrees
  • Gate size 79 mm
  • Aperture size Lens dependent
  • Pattern projection
  • Pattern size A or B (see manual)
  • Camera flicker control/ Hz range Yes, 1.2 K and 20 K
Control
  • Input method DMX Control
  • Protocols DMX / RDM via RJ45
  • Modes (Footprint) 1 ( 1- Intesity, 2- Red, 3- Green, 4- Blue, 5- Amber, 6- Strobe)
  • RDM configuration
  • UI type 7-segment address display
  • Onboard presets 12
  • Onboard sequences 5
  • FixtureLink support
Electrical
  • Voltage range 100–240 V (50–60 Hz)
  • Input method Hardwired, 1 m cord, bare end or various connector options (120 V), Hardwired, 1 m cord, bare end (240 V)
  • Inrush 32 A (first half-cycle) at 120 V, 60 A (first half-cycle) at 240 V
  • Fixtures per circuit* 120 V: 10 (20 A switched circuit, R20 module or similar), 240 V: 10 fixtures per non-dimmed circuit
  • (ER15AFR module)
  • Wattage (Typical/Standby): 146 W / 3.0 W (120 V), 143 W / 2.9 W (240 V)
  • Current draw 1.25 A at 120 V: 0.67 A at 240 V
*All measurements are for 120 V, 60 Hz. Results may vary in different regions.
Thermal
  • Ambient operating temp 5°–40° C (41°–104° F)
  • Fan
  • dB range 27 dBa (average at 1 m)
  • BTUs/hour 458 (120 V), 449 (240 V)
Physical
  • Materials Cast aluminum
  • Color Black
  • Mounting option Yoke
  • IP rating IP20, indoor only
  • Weight 3.6 lb (1.63 kg) (Retrofit only)
  • Included accessories Source 4WRD mounting post and reflector diffusion
Regulatory and Compliance
  • Approved regulatory standards: UL 1573 (complete luminaire), UL 1598C (retrofit kit), CSA C22.2 No. 166 (complete luminaire), CSA TIL B79-A (retrofit kit), CE Compliant
