Previously used unit
GENERAL INFORMATION
The Source 4WRD PAR and PARNel Fixture Bodies allow you to transform your Source 4WRD II LED into a beautiful softlight. Taking
advantage of the great energy efficiency, cool operating temperatures, DMX dimming or line voltage dimming and no lamp changes, the
Source 4WRD PAR and PARNel deliver amazing output without compromise.
APPLICATIONS
- Houses of worship
- Universities and schools
- Hospitality
- Retail
- Exhibition centers
- Meeting rooms
- Clubs
- Cafetoriums
PRODUCT FEATURES
- Fixture bodies for use with Source 4WRD II LED Retrofit
- Works just like a Source Four PAR or PARNel, using the same accessories
- 155 W at full output
- Brighter than the 750 W HPL versions
- Uses same Source 4WRD II LED as the Source 4WRD ellipsoidal
PRODUCT SPECIFICATIONS
Source
- LED details - S4WRD II LED *Not Included*
- Max lumens 10,786 (PARNel) w/ S4WRD II
- Lumens per watt 72 (PARNel)
- L70 rating (hours to 70% output) >45,000 hours (LM84 test pending)
Note - S4WRD II LED sold separately
Color
- Colors used Warm or Cool White
- Color temperature range 3200 K 80 or 90+ CRI, 5900 K 90+ CRI
Notes S4WRD is available in 80+ CRI (Standard) and 90+ CRI (Gallery) - See S4WRD datasheet for details
Optical
- Beam angle range PAR: 10–36°
- PARNel: 13–30°
- Aperture size 178 mm (7 in)
Notes PAR ships with an AR coated flat lens. Additional PAR lenses sold separately.
Control
- Input method Line Voltage with DMX Control or Line Dimmed
- Protocols DMX via RJ45 connector
- Modes (Footprint) 1
- RDM configuration
- UI type 7-segment address display
Notes Local level control via UI
Electrical
- Voltage range 114–125 V, 60 Hz (120 VAC), 209–252 V, 50 Hz (230 VAC)
- Input method Hard wired, 1 m cord, Edison plug (120 VAC), Hard wired, 1 m cord, bare end (230 VAC)
- Inrush 30 A (first half-cycle) at 120 VAC, 12 A (first half-cycle) at 230 VAC
- Fixtures per circuit* 120 VAC: 14 fixures per 20 A switched circuit (R20 module or similar), 230 VAC: 6 fixtures per non-dimmed circuit (ER15AFR module)
- Wattage (Typical/Standby) 150 W / 1.2 W (120 VAC), 175 W / 3.7 W (230 VAC)
- Current draw 1.26 A at 120 VAC, 0.75 A at 230 VAC
Notes - When using line dimming, see the S4WRD manual for dimmer setup.
- When using line dimming, standby power is 0 W.
*All measurements are for 120 V, 60 Hz. Results may vary in different regions.
Thermal
- Ambient operating temp 5°–50° C (41°–122° F)
- Fan
- dB range 28 dBa (average at 1 m)
- BTUs/hour 529 (120 VAC), 597 (230 VAC)
Physical
- Materials Die-cast aluminum
- Color White
- Mounting options - Yoke
- IP rating IP-20
- Weight PAR: 3 kg (6.6 lb) / PARNel: 3.5 kg (7.7 lb)
- Included accessories Color frame
Notes Includes S4WRD mounting post. Requires the S4WRD II LED available separately
Regulatory and Compliance
Approved regulatory standards cULus CE Compliant when used with ETC Source 4WRD LED Retrofit
