S4WRD UL GALRY RETROFIT W/ED BLK V2
$342.00
SKU:
7067A1114-A
Condition:
Used
Availability:
Previously used unit
GENERAL INFORMATION
Source 4WRD II (Watt Reduction Device) LED is a replacement for a standard Source Four burner assembly that converts the HPL source to a
white-light LED and provides a significant reduction in power consumption. The simple and quick upgrade is nondestructive and takes less than a minute. In most cases it can even be done without breaking the fixture’s focus. Source 4WRD II LED is theatrically dimmable via DMX or line dimmable, with a traditional LED curve, to allow flexibility for your installation. And, because it is an LED source, your fixtures will run cool and efficiently without lamp replacements.
APPLICATIONS
  • Energy saving retrofits
  • Houses of worship
  • Universities and schools
  • Hospitality
  • Retail
  • Exhibition centers
  • Meeting rooms
  • Clubs
  • Theatres
PRODUCT SPECIFICATIONS
Source
  • LED details S4WRD II LED
  • Max lumens (3200K Gallery/Daylight Gallery) 9,716
  • Lumens per watt (3200 K Gallery)
    • 120 V: 76.2/64.8/68.9
    • 230 V: 65.3/55.5/59.0
  • L70 rating (hours to 70% output) >45,000 hours
Color
  • Colors used Warm or Cool White
  • Color temperature range 3200 K 80 or 90+ CRI, 5900 K 90+ CRI
Optical
  • Field angle range Swappable lens tubes between 5–90 degrees
  • Gate size 79 mm
  • Aperture size Lens dependent
  • Pattern projection Yes
  • Pattern size A or B
Control
  • Input method - DMX Control or Line Dimmed*
  • Protocols DMX/RDM via RJ45
  • Modes (Footprint) 1 Channel (Intensity) for DMX
  • RDM configuration
  • UI type 7-segment address display, local level control via UI
  • Local control
Electrical
  • Voltage range 114–125 V, 60 Hz (120 V), 209–252 V, 50/60 Hz (230 V)
  • Input method Edison Plug (120 V)
  • Inrush 30 A (first half-cycle) at 120 V, 12 A (first half-cycle) at 230 V
  • Fixtures per circuit 120 V: 14 (20 A switched circuit, R20 module or similar), 230 V: 6 fixtures per non-dimmed circuit (ER15AFR module)
  • Wattage (Typical/Standby) 150 W/1.2 W (120 V), 175 W/3.7 W (230 V)
  • Current draw 1.26 A at 120 V, 0.75 A at 230 V
  • Notes
-       When using line dimming, see the S4WRD manual for dimmer setup.
-       When using line dimming, standby power is 0 W.
Thermal
  • Ambient operating temp 5°C to 50°C (41°F to 122°F)
  • Fan dB range 28 dBa (average at 1 m)
  • BTUs/hour 529 (120 V), 597 (230 V)
Physical
  • Materials Die-cast aluminum
  • Color Black
  • IP rating IP-20, indoor only
  • Weight 3.73 lb (1.69 kg) (Retrofit only)
  • Included accessories Source 4WRD mounting post
Regulatory and Compliance
  • Approved regulatory standards
    • UL 1573 (complete luminaire)
    • UL 1598C (retrofit kit)
    • CSA C22.2 No. 166 (complete luminaire)
    • CSA TIL B79-A (retrofit kit)
    • CE Compliant
