Previously used unit
Fixture Overview
When you need an automated lighting product that cuts through the haze, a fixture with the power to shine in the world’s largest venues, you need the SolaHyBeam 3000. Powered by an exceptionally efficient White Light LED engine, the large front aperature and optimized long-throw optics give you even more light as you approach the fixture’s wonderous narrow zoom. Add in a feature set designed for beam control and aerial effects, and what you get is a fixture that can throw light from the back of the house, to the front, and all the way back again. All while lighting the haze aflame with color and light.
Applications
- Arenas and stadiums
- Large theatres
- Film and television broadcast studios
- Large scale events
- Megachurches and houses of worship
Product Features
- Bright white LED engine
- 750 W Ultra-Bright engine producing 37,000 field lumens
- Massive 210 mm glass front lens with patented Lens Defogger
- Extremely powerful 4.5°–50° zoom
- CMY/CTO - Linear color mixing system
- Six position plus open replaceable Color Wheel
- Framing system for total control of beam shaping
- 16-blade iris for extremely tight beam effects
- Beautifully linear Trifusion frost system
- Seven position plus open Rotating Gobo Wheel
- Three Prisms on two planes, unleashing dual-prism effects
- TM-30 Filter boosts the Ultra-Bright Engine color rendering
PRODUCT SPECIFICATIONS
Source
- Engine Option Ultra-Bright
- LED Details 750 W
- Max Field Lumens 37,000 lumens
- Integrating Sphere Lumens 40,000 lumens
- LPW 47
- LED Life 50,000 hours
- Native CCT 6700 K
- Transferable Light Engine
Color
- Color Mixing Cyan, magenta, yellow, CTO-linear
- Color Temperature Variable down to 2800 K
- Color Wheel Six (6) interchangeable dichroic chips plus open including TM-30 filter standard
Optical
- Beam Angle Range 4.5–50°
- Gate Size 30 mm (1.2 in)
- Aperture Size 210 mm (8.27 in)
- Pattern Projection Rotating and indexable wheel with seven (7) patterns plus open
- Animation LED Animation
- Prism Three prisms on two planes for simultaneous prisms
- Frost Trifusion for smooth and even linear frost with bright edgeless design
- Iris 16-blade iris
- Framing Four-plane, full-curtain framing system with 90° module rotation
- Flicker Control/Hz Range 100 Hz, 2.4 kHz, or 16 kHz
Control
- Input Method DMX (5-pin) or Ethernet
- Protocols DMX via RS-485, Art-Net or sACN via Ethernet
- Ethernet Pass-Thru Passive Ethernet in and thru with and without power
- Data Conversion
- Patented data conversion system for: DMX to Ethernet, Ethernet to DMX
- Modes (Footprint) One (53)
- RDM Functions
- UI Type Full color graphical UI with 6-button navigational control
- Local Control
- Dimming Performance 16-bit, DMX controlled
Electrical
- Voltage Range 100-240 VAC, 50-60 Hz
- Input Method powerCON TRUE1
- Wattage (Max) 1,276 W
- Current (Max) 12.8 A @ 100 V
Thermal
- Ambient Operating Temp -10°–45°C (14°–113°F)
- Fan Mode Standard, Studio, Continuous, Studio Continuous
- Stationary Noise: Standard - 35.6 dBA, Studio - 28.4 dBA, Continuous - 40.4 dBA, Studio Continuous - 35.8 dBA
- Lens Defogging Patented Lens Defogger included
Physical
- Pan and Tilt Range 540° pan, 253° tilt
- Max Pan/Tilt Speed 360° in 3.1 s / 180° in 2.02 s
- Materials Steel and aluminum frame with molded plastic covers
- Color Black
- Mounting Options Any orientation
- IP Rating IP20
- Weight 50.8 kg (112 lbs)
Included Accessories
- powerCON TRUE1 to bare end fixture tail, Two (2) clamp brackets, Safety cable
Regulatory & Compliance
- Regulatory Standards: Listed to UL 1573, Certified to CSA STD. C22.2 No: 166, EAC
- CE compliance declared to these standards: Safety: EN 60598-1, EN 60598-2-17, EN 62031, EN 62471
- EMC: EN 55015, EN 61547, EN 61000-3-2, EN 6100-3-3
- Complies to the ROHS directive
Safety
- Minimum distance to illuminated surface = 2.0 m (6.5 ft)
- Minimum distance from fixture head to combustible materials = 0.1 m (0.33 ft)
Note: All LED sources experience some lessening of light output and some color shift over time. LED output will vary with thermal conditions. Thermal conditions can be affected by ambient temperatures and orientation.
