Previously used unit
GENERAL INFORMATION
The SolaPix family of wash fixtures from High End Systems takes the traditional concept of a pixel wash and pushes it to its maximum potential, and the SolaPix 19 XT takes it even further with an IP65
design specifically for temporary usage in exterior applications. As both a vacuum- and liquid-sealed product, this weatherproof fixture can go anywhere and be ready for the next gig. Whether you are using the fixture to spread color all over a festival stage or outdoor event, the bright and punchy output will envelop your production with beautiful, saturated color. Additionally, when you need to add emphasis, the narrow zoom and fully macro- and pixel-controlled face gives you a wide variety of looks and effects to help set the mood and steal the show in any weather.
Applications
- Indoor or outdoor
- Live concerts
- Tradeshows
- Festivals
- Industrial shows
- Outdoor film sets
- Corporate events
Product Features
- Designed for temporary outdoor use with rainproof and dustproof enclosure
- Additive LED, RGBW, color mixing system for extremely powerful saturated colors and tunable white control
- Versatile 4.5°–60° zoom
- Extremely efficient optical system provides market-leading lumen output
- FleX Effects Generator for easily customizable macros
- Pixel mapping on all models
- Modular control with Art-Net or sACN in addition to simultaneous DMX control
- Patent-Pending HaloGraphic Pixel Definition
- Also see the entire family of SolaPix interior-rated fixtures at etcconnect.com
PRODUCT SPECIFICATIONS
Source
- LED Quantity 19
- Max. Field Lumens 11,815
- Integrating Sphere Lumens 13,800
- LPW 16
- LED Type 40 W Osram Ostar LED
- LED Life 50,000 hours/5 year warranty
Color
- Color Mixing Red, green, blue, and white
- Color Temperature Range Variable from 2800-8000 K
Optical
- Beam Angle Range 4.5°–60°
- Flicker Control/Hz Range 2.4 kHz and 16 kHz
Control
- Input Method DMX (5-pin) or Ethernet
- Protocols DMX via RS-485 Art-Net or sACN via Ethernet
- RDM Functions
- UI Type Full color graphical UI with 6 button navigational control
- Local Control
- Effects Engine Built in effects engine with multi parameter color and speed control
- Pixel Mapping Individual addressing via DMX, Art-Net, or sACN
- Dimming Performance 16-Bit, DMX controlled
Electrical
- Voltage Range 100–240 V 50–60 Hz
- Input Method powerCON TRUE1 TOP
- Wattage (Standard) 1000 W @ 100 V
- Current (Max) 9.5 A @ 100 V
- Inrush (First Half Cycle) 120 V: 27.6 A 230 V: 96.0 A
- Fixtures per Circuit 1 fixture (15 A power thru connector), 2 fixtures (R20 module or similar)
- Note: TRUE1 TOP connector rated for 20 A (120 V / 60 Hz) and 16 A (240 V / 50 Hz)
Thermal
- Ambient Operating Temp -10° to 40°C (14° to 104°F)
- Fan Mode Standard, Studio, and Linear Continuous control channel
Physical
- Pan and Tilt Range 540° pan, 263° tilt
- Max Pan/Tilt Speed 360° in 2.44 s/180° in 1.00 s
- Materials Steel and aluminum frame with aluminum and plastic covers
- Color Black
- Mounting Options Any orientation
- IP Rating IP65
- Weight 27.2 kg (60 lb)
- Included Accessories: Two (2) 180 mm Single-hole Omega brackets, Two (2) clamp brackets, Safety cable
Regulatory & Compliance
- Approved regulatory standards: cETLus Listed, Listed to UL 1573, Certified to CSA STD. C22.2 No: 166, CE Compliant, UKCA Compliant
- Complies to the ROHS directive
Safety
- Minimum distance to illuminated surface = 1.0 m (3.2 ft)
- Minimum distance from fixture head to combustible materials = 0.1 m (4.0 in)
Notes: All LED sources experience some lessening of light output and some color shift over time. LED output will vary with thermal conditions. Thermal conditions can be affected by ambient temperatures and orientation
