SOLAPIX 7 CPU2 BLK BOXED W/MI
$1,902.75
SKU:
2594A1010-B
Condition:
Used
Availability:
Usually ships in 7-10 business days. Expedited shipping options are not available through the website. For faster shipping methods or deliveries to international locations, Alaska, Hawaii, or U.S. Outlying Territories, please contact Customer Service
Previously used unit
GENERAL INFORMATION
Fixture Overview
The SolaPix family of wash fixtures from High End Systems takes the traditional concept of a pixel wash and pushes it to its maximum potential. Whether you are using the fixture to spread color all over a ballroom, tradeshow floor, or concert stage, the bright and punchy output will envelop your production with beautiful saturated color.  Additionally, when you need to add interest, the narrow zoom and fully macro- and pixel-controlled face gives you a wide variety of looks and effects to help set the mood and steal the show.
Applications
  • Live concerts
  • Tradeshows
  • Festivals
  • Industrial shows
  • Award shows
  • Studios
  • Theatre
  • Corporate events
Product Features
  • Additive LED, RGBW, color mixing system for extremely powerful saturated colors and tunable white control
  • Versatile 4.5°–60° zoom
  • Extremely efficient optical system provides market-leading lumen output
  • FleX Effects Generator for easily customizable macros
  • Pixel mapping on all models
  • Modular control with Art-Net, or sACN in addition to simultaneous DMX control
  • Patent-Pending HaloGraphic Pixel Definition
PRODUCT SPECIFICATIONS
Source
Fixture Type SolaPix 7
LED Quantity 7
Max. Field Lumens 5,500
Integrating Sphere Lumens 5,600
LPW 20
LED Type 40 W Osram Ostar LED
LED Life 50,000 Hours / 5 year warranty
Color
Color Mixing Red, Green, Blue, and White
Color Temperature Range Variable from 2800–8000 K
Optical
Beam Angle 4.5°–60°
Flicker Control/Hz
Range 2.4 kHz, 16 kHz
Control
Input Method DMX (5-pin) or Ethernet Protocols DMX via RS-485 Art-Net, or sACN via Ethernet
RDM Functions
UI Type Full color graphical UI with 6 button navigational control
Local Control
Effects Engine Built in effects engine with multi parameter color and speed control
Pixel Mapping Individual addressing via DMX, Art-Net, or sACN
Dimming Performance 16-Bit, DMX controlled
Electrical
Max Wattage 400 W
Max Current 4.0 A @ 100 V 1.7 A @ 240 V
Inrush (First Half Cycle)120 V: 57 A 230 V: 78 A
Fixtures Per Circuit 5 fixtures (R20 module or similar)
Voltage Range 100–240 V 50–60 Hz 120–240V 50–60Hz
Input Method powerCON TRUE1
Thermal
Ambient Operating Temp 0°–40° C (32°–104° F)
Fan Mode Standard, Studio, User fan control channel
Physical
Pan and Tilt Range 540° Pan 255° Tilt
Max Pan/Tilt Speed
Pan - 360° in 1.2 s Tilt -180° in 0.66 s
Weight 9.1 kg (20 lb)
Materials Steel and aluminum frame with molded plastic covers
Color Options Black, white by request
Mounting Options Any orientation
IP Rating IP-20
Included Accessories powerCON TRUE1 TOP to bare end fixture tail, Two (2) Omega brackets, Safety cable
