Source 4 JR 26 Degree W/O Connector CE
$178.75
SKU:
7062A1001
Condition:
Used
Availability:
Previously used unit
GENERAL INFORMATION
PHYSICAL
  • No connector, bare end wires
  • Rugged die cast aluminum construction
  • 20 gauge stainless steel shutters in a bi-plane assembly
  • Interchangeable lens tubes with smooth–running Teflon guides provide three user-fit field angle options
  • High impact, thermally insulated knobs and shutter handles
  • Two accessory slots, and a top mounted, gel frame retainer
  • Steel yoke with two mounting positions positive locking, hand-operated yoke clutch
  • Slot for stainless steel patterns
  • Slot with sliding cover for motorized pattern devices or optional iris
  • CE Listed
ELECTRICAL
  • 115-240V, 50/60Hz
  • High temperature 3–conductor 36” leads in a glass fiber outer sleeve
  • Supports etc Dimmer Doubling™ technology
LAMP
  • HPL — compact tungsten filament contained in a krypton-filled quartz envelope (see table for suitable lamp types)
  • 575W Maximum
  • Integral die cast aluminum heat sink lamp base
OPTICAL
  • Optimized optical system for efficient photometric performance
  • Projector-quality, high contrast aspheric lens
  • Faceted borosilicate reflector with dichroic cold mirror coating removes greater than 90% infrared radiation (heat) and reflects greater than 95% of visible light
  • Reflector secured with anti-vibration shock mounts
  • Tool free, positive locking X, Y and Z lamp centering adjustments, unaffected by relamping
  • Beam edge continually adjustable hard-to-soft
  • Interchangeable lens assembly kits permit selection of 26°, 36°, and 50° field angles, and 25°-50° zoom range
