Previously used unit
GENERAL INFORMATION
PHYSICAL
- Rugged die–cast aluminum construction
- High–impact, thermally insulated precision focus knob
- Sealed reflector housing
- Reflector temperature control through integral heat sink fins
- Gel frame holders with two accessory slots
- Top-mounted, gel-frame retainer
- Steel yoke with two mounting positions
- Positive locking yoke clutch
- UL and cUL Listed
ELECTRICAL
- 115–240 V, 50/60 Hz
- High-temperature three-conductor 36” leads in a glass fiber outer sleeve
- Supports ETC Dimmer Doubling technology
LAMP
- HPL – compact tungsten filament contained in a krypton/xenon-filled quartz envelope (see page 3 for suitable lamp types)
- 750 W maximum
- Patented filament geometry makes for extremely efficient light collection and transmission
- Integral die-cast aluminum heat sink lamp base
LENSES
- Patented wave lens system
- Two heat resistant borosilicate glass lenses
- One fixed wave clear lens and one rotatable wave stippled lens installed
- Tool free front lens changing
- Thermally insulated lens ring
OPTICAL
- Integral 25°–45° spot to flood adjustment
- Modified parabolic and multifaceted reflector
- Computer designed reflector facets molded directly into heat sink casting, finished with an enhanced aluminum deposition process, and polished for maximum reflectance
