TALEN BOXED W/FOAM
$646.75
SKU:
2592A1000
Condition:
Used
Availability:
Usually ships in 7-10 business days. Expedited shipping options are not available through the website. For faster shipping methods or deliveries to international locations, Alaska, Hawaii, or U.S. Outlying Territories, please contact Customer Service
Previously used unit
GENERAL INFORMATION
SourcWith its punchy, rig-defining aerials, Talen adds visual excitement and bigger looks to any show. The compact fixture’s high intensity
beams are created with full additive color RGBW emitters and a large front aperture, resulting in an extremely narrow 3° beam with high
center beam candlepower. With infinite pan and tilt movement, Talen moves beyond position limitations. Talen’s footprint is small
enough to fit anywhere in a lighting rig, and it can also be rigged in multiform, creative hanging positions with the Talen Array Hinge.  Fixtures can be easily configured and addressed through the ETC Set Light app
APPLICATIONS
  • Large scale nightclubs
  • Touring and live music venues
  • Theme parks and cruise ships
  • Houses of worship
  • Retail applications
PRODUCT FEATURES
  • Additive color mixing with Red, Green, Blue, and White emitters
  • 60 W LED with an ultrasmall light emitting surface for extreme narrow output and high center beam output
  • Custom 120 mm Total Internal Reflection (TIR) optic
  • 3° beam with high center beam candlepower
  • Infinite pan and tilt
  • Whisper Home calibration with patented absolute encoding
  • Fixture configuration and addressing via the ETC Set Light app over Bluetooth®
  • Unique rigging opportunities through the Talen Array Hinge
PRODUCT SPECIFICATIONS
 Source
  • Engine Osram® RGBW LED
  • LED Details 60 W
  • Max Field Lumens 1,400 lumens
  • Integrating Sphere Lumens 1,564 lumens
  • LPW 24
  • LED Life 50,000 hours
 Color
  • Color Mixing - Red, Green, Blue, White
 Optical
  • Beam Angle 3°
  • Center Lux @ 3 m 27,000 lux
  • Aperture Size 120 mm
  • Flicker Control/Hz Range 24 kHz
 Control
  • Input Method DMX (5-pin)
  • Protocols DMX via RS-485
  • Modes (Footprint) One (13)
  • RDM Functions
  • UI Type Configurable via the ETC Set Light app over Bluetooth
  • No Local ControL
  • Dimming Performance 8-bit, with RDM settable internal smoothing
 Electrical
  • Voltage Range 100-240 V, 50-60 Hz
  • Input Method TRUE1-compatible locking connector
  • Wattage (Max) 118 W
  • Current (Max) 1.2 A @ 100 V
  • Inrush (First Half Cycle) 120 V: 21.6 A, 230 V: 24.2 A
  • Fixtures per Circuit on Standard R20 Breaker - 11 (link up to 12 fixtures via Power Thru connector)
  • Note: Connector rated for 15 A (120 V / 60 Hz) and 15 A (240 V / 50 Hz)
 Thermal
  • Ambient Operating Temp -10°C to 40°C (14°F to 104°F)
  • Fan Mode Standard fan mode
 Physical
  • Pan and Tilt Range Infinite pan and tilt with Whisper Home technology and absolute encoded positioning
  • Max Pan/Tilt Speed 360° in 1.49 s / 180° in 0.58 s
  • Materials Steel and aluminum frame with molded plastic covers
  • Color Options Black, white by request
  • Mounting Options Any orientation
  • IP Rating IP20
  • Weight 6 kg (13.2 lb)
  • Included Accessories
    • TRUE1-compatible locking connector to 515 Edison tail
    • One (1) clamp brackets
    • Safety cable
 Regulatory & Compliance
  • Approved regulatory standards
    • cETLus Listed
    • Listed to UL 1573
    • Certified to CSA STD. C22.2 No: 166
    • CE Compliant
    • UKCA Compliant
  • Complies to the ROHS directive
 Safety
  • Minimum distance to illuminated surface = 1.0 m (3.3 ft)
  • Minimum distance from fixture head to combustible materials = 0.1 m (0.33 ft)
