VIVID ICE LED FIXTURE 11
$848.00
SKU:
7400A1191
Availability:
Previously used unit
Vivid Ice SL3 11" LED Fixture
GENERAL INFORMATION
The Selador Series Vivid ice LED fixture combines the strength of the x7 Color system with the power of leDs to provide a highly efficient fixture for color washes at the blue end of the spectrum.  LEDs are used to their greatest potential – providing the deep saturated colors that designers need to color their stages efficiencies much greater than a tungsten source with deep color gels. x7 Color system elements enable Vivid ice to produce Congo-like indigos and a full range of warm blues, moonlight blues, teals, blue-greens and greens.  Vivid ice and its companion Vivid fire fixtures are ideal for stage and studio as a deep color tool in any lighting system.
No accessories or lensing included beyond what ships with new product.
APPLICATIONS
  • Theaters
  • Themed entertainment
  • TV/film Studios
  • Churches
  • Schools
GENERAL
• 2.5W color-mixing LED fixture
• available in 11” and 21” lengths
• ETL rated for indoor dry location use
PHYSICAL
  • Rugged all-metal extruded housing
  • Advanced thermal management systems for long LED life
  • Easy-access slots for secondary lenses
  • Combine secondary lenses for desired horizontal and vertical beam spread
  • Available in black (standard)
  • Yoke (single and double, 11” and 21”), trunnion (floor stand), and hanging bracket mounting options
ELECTRICAL
  • 100VaC to 240V 50/60 Hz universal power input
  • Neutrik® PowerCon™ input connector
  • 5’ power lead (parallel-blade, U-ground) supplied (see page 1 for input connector options)
  • Requires power from non-dim source
  • Low-speed, low-noise cooling fan for thermal stability
LED
  • 50,000 hr. LED life
  • 40 luxeon® rebel 2.5W LED emitters per cell
COLOR
  • Exclusive x7 Color System™ specialized 5-color LED array
  • Ice – optimized for a full range of blues, teals, lavenders and greens
  • Interacts seamlessly with conventional sources
OPTICAL
  • Native beam spread of approximately 26°
  • Secondary lenses install in fixture front to change distribution of light
  • Use a combination of vertical and horizontal lenses to spread light both directions
  • Lenses must be ordered separately
  • Refer to accessories for lenses available
CONTROL
  • DmX512 in and thru via 5-pin XLR connectors
  • 6 channel control (5 color plus intensity)
  • Intensity channel minimizes color shift during dimming
  • 15-bit internal control for smooth low-end dimming
  • 11” fixture provides one controlled cell
THERMAL
  • On-board fan speed control for no-noise operation except when required
  • Ambient operating temperature of 32°-104°f (0°- 40°C)
  • Fixture case can become extremely hot (approx. 85°C) under long-term, high-output, continuous usage
  • Fixture is designed for continuous usage at 40°C ambient temperature. requires free air flow around fixture.
