Previously used unit
Includes 90 day warranty.
Vivid-R SL3 11" LED Fixture
GENERAL INFORMATION
The Selador Series Vivid-R fixture replaces Vivid as ETC’s strong color, long-throw LED fixture. Highly efficient primary lenses and careful color choices make Vivid-R brighter than the original Vivid while using less power. Vivid-R is ideal for stage, studio and anywhere strong color and high intensity lighting is required. It uses the x7 Color System to produce the widest range of spectrally balanced saturated and tinted colors available. Lighting designers will love the deep, pure colors teamed with high-power color punch. While maximized for high-brightness and deep color output, Vivid-R does not give up Selador Series’ unique ability to match warm, tungsten white light, vibrant daylight white, and soft, tinted gel colors.
No accessories or lensing included beyond what ships with new product.
APPLICATIONS
- Theaters
- Themed entertainment
- TV/Film studios
- Houses of worship
- Hotels
- Convention centers
- Schools
GENERAL
- 2.5W color-mixing LED fixture
- Available in 11in, 21in, 42in, and 63in lengths
- ETL rated for indoor dry location use
PHYSICAL
- Rugged all-metal extruded housing
- Easy-access slots for secondary lenses
- Combine secondary lenses for desired horizontal and vertical beam spread
- Available in black (standard)
- Yoke (11in and 21in only), trunnion (floor stand), and hanging bracket mounting options
ELECTRICAL
- 100VAC to 240VAC 50/60 Hz universal power input
- Neutrik® PowerCon™ input connector
- 5ft power lead (parallel-blade, U-ground) supplied (see page 1 for input connector options)
- Requires power from non-dim source
LED
- 50,000 hr. LED life
- 40 Luxeon® Rebel 2.5W LED emitters per cell
COLOR
- Exclusive x7 Color System™ 7-color LED array
- Vivid-R – optimized for strong saturated colors at maximum brightness
- Interacts seamlessly with conventional sources
- Beautifully illuminates skin tones and other objects, for a natural appearance with high color rendering
- Strong saturated colors with maximum punch
OPTICAL
- Native tight beam spread of approximately 19°
- Secondary lenses install in fixture front to change distribution of light
- Use a combination of vertical and horizontal lenses to spread light both directions
- Lenses must be ordered separately
- Refer to accessories for lenses available
CONTROL
- DMX512 in and thru via 5-pin XLR connectors
- Eight channel control (seven color plus intensity)
- Intensity channel minimizes color shift during dimming
- 15-bit internal control for smooth low-end dimming
- 11in fixture provides one controlled cell
THERMAL
- Ambient operating temperature of 32°-104°F (0°- 40°C)
- Fixture case can become extremely hot (approx. 85°C) under long-term, high-output, continuous usage
- Fixture is designed for continuous usage at 40°C ambient temperature. Requires free air flow around fixture
- Fan speed thermostatically controlled for no-noise operation except as required for high heat or low air flow situations
