ZEO BLACK W/ MOLDED INSERT
$3,617.00
SKU:
2593A1000-B
Previously used unit
GENERAL INFORMATION
The High End Systems Zeo is a genre-defying fixture. Packing ultimate brightness, the Zeo can be used as a strobe or blinder to heighten the energy at any show. Create captivating looks with Zeo’s unique face design, highlighted by a central LED monolith,
four reflectors, and four powerful RGBW engines. Zeo’s focus concentrates the light throughout the fixture’s 55° field angle. And the many looks of Zeo are easily accessible with an abundance of macros to choose from.
Applications
  • Performance spaces of all sizes
  • Let creativity be your guide
Product Features
  • LED monolith with four 300 W RGBW LED cells
  • Individual cell control
  • Fixture output exceeding 30,000 lumens
  • Patented Quad Reflector system
  • HaloGraphic Pixel Definition technology
  • Motorized Light Concentration system
  • Optional accessory beam homogenizer for enhanced color mixing
  • Strobe and inclusive macros with separate background levels to enhance shows at all programming levels
PRODUCT SPECIFICATIONS
Source
  • Engine Quantity four, each 300 W RGBW COB
  • LED Details 1,200 W
  • Field Lumens See photometrics on page 3
  • Max Integrating Sphere Lumens 30,000 lumens
  • LPW 25
  • LED Life 50,000 hours
  • Native CCT None
Color
  • Color Mixing Red, Green, Blue, White, CTO
  • Color Temperature 2,200 K to 10,000 K
Optical
  • Light Concentration Control Motorized, beam from 13° to 55°
  • Aperture Size 285 x 285 mm
  • Diffusion Optional beam homogenizer accessory
  • Flicker Control/Hz Range 2.4 kHz and 16 kHz
Control
  • Input Method DMX (5-pin) or Ethernet
  • Protocols DMX via RS-485
  • Art-Net or sACN via Ethernet
  • Ethernet Pass-Thru Passive Ethernet in and thru with and without power
  • Data Conversion Patented data conversion system for Ethernet to DMX
  • Modes (Footprint)
  • Standard (51 channels)
  • Reduced (23 channels)
  • Wash (15 channels)
  • Effects Capabilities
  • Inclusive macros
  • Strobe macros
  • Individual cell mapping
  • RDM Functions Yes
  • UI Type Full-color graphical UI and 5-button navigational control
  • Local Control
  • Dimming Performance 16-bit, DMX controlled
Notes: All LED sources experience some lessening of light output and some color shift over time. LED output will vary with thermal conditions.  Thermal conditions can be affected by ambient temperatures and orientation.
Electrical
  • Voltage Range 100–240 V 50–60 Hz
  • Input Method powerCON TRUE1 TOP
  • Wattage 1,670 W
  • Current (Max) 16.8 A @ 100 V, 6.5 A @ 240 V
  • Inrush (First Half Cycle) 120 V: 69 A, 230 V: 123 A
  • Fixtures per Circuit 1 fixture (R20 module or similar)
  • Note: TRUE1 TOP connector rated for 20 A (120 V/60 Hz) and 16 A (240 V/50 Hz)
Thermal
  • Ambient Operating Temp -10°C to 40°C (14°F to 104°F)
  • Cooling System Fan-cooled closed-loop liquid cooling system
  • Fan Mode Standard, Studio, and Linear Continuous control channel
Physical
  • Pan and Tilt Range 540° pan, 205° tilt
  • Max Pan/Tilt Speed 360° in 2.39 s/180° in 1.92 s
  • Materials Steel and aluminum frame with molded plastic covers
  • Color Options Black, white by request
  • Mounting Options Any orientation
  • IP Rating IP20
  • Weight 20 kg (44 lb)
  • Included Accessories
  • powerCON TRUE1 TOP to bare end fixture tail, Two (2) 107 mm three-hole Omega brackets, Safety cable
Regulatory & Compliance
  • Approved regulatory standards
    • cETLus Listed
    • Listed to UL 1573
    • Certified to CSA STD. C22.2 No: 166
    • CE Compliant
    • UKCA Compliant
    • Complies to the ROHS directive
Safety
  • Minimum distance to illuminated surface = 2.0 m (6.7 ft)
  • Minimum distance from fixture head to combustible materials = 0.1 m (4.0 in)
