Previously used unit
Includes 90-day warranty - if the used item fails within this period, it may be returned for a refund or a warranty repair.
GENERAL INFORMATION
The ETC Desire D40 fixture puts the seven-color x7 system into a round theatrical washlight. Highly efficient primary lenses and careful color choices make the D40 fixture ideal for stage, studio and anywhere strong color and high-intensity are requirements. The x7 Color System produces the widest range of spectrally-balanced saturated and tinted color choices available. D40’s rugged die-cast enclosure, noiseless fan- free operation, multiple lens options and advanced user interface make it ideal for multiple applications.
D40 fixtures are based on the x7 Color System, which uses seven different LED colors to achieve true, usable broad-spectrum color. The D40 luminaire is available with any one of the following x7 color arrays (not interchangeable) to best suit the intended application:
• D40 Vivid – the x7 Color System array balanced for best all-around use as a high-intensity color-changing wash fixture.
PRODUCT SPECIFICATIONS
Source
- LED details 40 Lumileds LUXEON® Rebel LED
- Max lumens Vivid: 2,252
- Lumens per watt Vivid: 21.9
- L70 rating (hours to 70% output) 50,000 hours
Color
- Colors used Vivid: Red, Red-Orange, Amber, Green, Cyan, Blue, Indigo
- Color temperature range 2,700–6,500 K
- Calibrated array
- Red shift
Optical
- Beam angle range 10°–71°*
- Aperture size 7.5 in
- Camera flicker control/Hz range: 900–25,000 Hz
* Note Secondary lenses available for multiple beam-spread options
Control
- Input method DMX512 via 5-pin XLR
- Protocols DMX-512/RDM
- RDM configuration
- UI type LCD
- Local control
- Onboard presets
- Onboard sequences
- Fixture-to-fixture control
- Notes 15-bit virtual dimming engine
Electrical
- Voltage range 100–240 VAC 50/60 Hz
- Input method Neutrik powerCON in and thru
- Inrush 15 A at 120 V (First half-cycle), 40 A at 240 V (First half-cycle)
- Fixtures per circuit* 9 (15 A power thru connector), 10 (R20 module or similar)
- Wattage typical 103
- Current draw 0.82 A at 120 V, 0.40 A at 240 V
*All measurements are for 120 V, 60 Hz. Results may vary in different regions.
Thermal
- Ambient operating temp -20°–40°C (-4°–104°F)
- Droop compensation
- dB range N/A
- BTUs/hour 351
Physical
- Materials Die-cast, all metal housing
- Color Black
- Yoke Mounting
- IP rating IP20
- Weight 6.4 kg (14 lb)
Notes Easy access slots for secondary lenses and standard 7.5 inch PAR acessories
Regulatory and Compliance
Approved regulatory standards: UL 1573, CSA C22.2 No. 166, CE Compliant, EAC Compliant
