Previously used unit
GENERAL INFORMATION
ETC’s Desire Series D40XT puts the seven-color x7 system into a round theatrical wash light fully sealed and rated for IP66 outdoor use. The Selador® x7 Color System™ produces the widest range of spectrally-balanced saturated and tinted color choices available. The D40XT offers a rugged die-cast enclosure, noiseless fan-free operation, multiple lens options and advanced user interface. Its watertight construction makes it ideal for outdoor events and installations.
D40XT LED ARRAY OPTIONS
D40XT fixtures are based on the x7 Color System that uses seven different LED colors to achieve true, usable broad-spectrum color. The D40XT luminaire is available with any one of the following x7 color arrays to best suit the intended application.
• D40XT Fire™ – uses the warm colors of the x7 System to provide extra-high brightness color in the red end of the spectrum
GENERAL
- 40 X 2.5W LED variable color-mixing light wash fixture
- ETL listed to UL1573 – the standard for stage and studio lighting units
- IP66-rated for exterior wet location use
- Power and DMX in/thru connections for easy setup
- User-friendly control interface with multiple modes and fixture settings
PHYSICAL
- Rugged die-cast all-metal housing
- Easy access slots for secondary lenses and standard 7.5” PAR accessories
- Available in black (standard), white or silver (optional) or custom colors (contact factory)
- Hanging yoke standard. Optional yoke/floor stand available
- Effective Projected Area (EPA): 0.74
ELECTRICAL
- 100VAC to 240VAC50/60 Hz universal power input
- Waterproof, 39”power in and thru outdoor rated power leads
- Up to nine fixtures (15A max) may be linked via power thru connector (ten fixtures total per circuit) when used with R20
- Relay Module or Unison Echo Relay Panel. Consult breaker trip curves when used with other equipment
- Requires power from a non-dim source
- Inrush- 120V: 15A (First half-cycle), - 240V: 40A (First half-cycle)
LED
- 50,000 hour LED life (50,000 hours to 70% intensity)
- 40 Luxeon® Rebel 2.5W LED emitters
COLOR
- Exclusive x7 Color System™ seven-color LED array
- Broad spectrum color interacts seamlessly with conventional sources
- Beautifully illuminates skin tones and other objects for natural appearance and high color rendering
- Exclusive red-shift option emulates tungsten dimming performance
OPTICAL
- Primary field angle of 17° and beam angle of 8°
- Secondary lenses available for multiple beam spread options
- Sealed, factory-installed lenses available for permanent installations (special order)
- Lenses must be ordered separately
- Refer to accessories chart for lenses available
CONTROL
- DMX512 in and thru via watertight five-pin XLR connectors on 39” leads
- Multiple control options including RGB, strobe, and console-free Master/Slave mode
- See DMX Control Table for additional information
- 15-bit virtual dimming engine provides smooth, high quality theatrical fades and minimizes color shift during dimming
- RDM functionality for address and setting changes
THERMAL
- Ambient operating temperature of -4° to 104°F (-20° to 40°C)
- Active electronic thermal management for droop-free operation
- Noiseless, fan-free convection cooling for acoustically sensitive installations
- Fixture is designed for continuous operation up to 104°F (40°C) ambient temperature and requires free flow of air around fixture housing
