Previously used unit
GENERAL INFORMATION
The Selador Desire D40XTI brings the amazing control of the seven-color x7 Color System to your permanent application. With its IP66 rating, this fixture is ready for installation inside or outside – wherever you need it. The x7 Color System produces the widest range of spectrally-balanced saturated and tinted color choices available. The D40XTI offers a rugged die-cast enclosure, noiseless fan-free operation, and multiple lens options that can be changed on-site
No accessories or lensing included.
D40XTI Studio LED Array Options
D40XT Studio LED Array Options
D40XTI Studio HD: Combines warm-white and cool-white LEDs with five carefully-chosen x7 LED colors, to fill in white LED spectral apps with variable color-temperature mixing for the richest variable white light possible in an LED fixture
PRODUCT SPECIFICATIONS
Source
- LED details 40 Lumileds LUXEON® Rebel LED
- Max lumens Studio HD: 3,194
- Lumens per watt Studio HD: 33.2
- L70 rating (hours to 70% output) 50,000 hours
Color
- Colors used Studio HD: Red, Amber, Green/Cyan, Blue, Warm White, Cool White
- Color temperature range 2,700–6,500 K
- Calibrated array Studio HD: Yes
- Red shift Yes (not available on static-white)
Optical
- Beam angle range 8°–17°
- Gate size N/A
- Aperture size 7.5 in
- Pattern projection No
- Pattern size N/A
- Camera flicker control/Hz range, Yes: 900–25,000 Hz
Control
- Input method DMX512 via termination board
- Protocols DMX512/RDM
- RDM configuration Yes
- Onboard presets Yes
Control
- Onboard sequences Yes
- Notes: 15-bit virtual dimming engine
Electrical
- Voltage range 100–240 VAC 50/60 Hz
- Input method Waterproof, 72 in power lead, requires power from non-dimmable source
- Inrush 15 A at 120 V (First half-cycle)
- 40 A at 240 V (First half-cycle)
- Fixtures per circuit* 10 (15 A may be fed on same circuit)
- Wattage typical 110
- Current draw 1/0.5 A
*All measurements are for 120 V, 60 Hz. Results may vary in different regions.
Thermal
- Ambient operating temp -20°–40° C (-4°–104° F)
- Fan (controllable) No
- Droop compensation Yes
- dB range N/A
- BTUs/hour 375.32
Physical
- Materials Die-cast, all metal housing
- Color options Black, white, silver, or custom color
- Mounting options Single-pole mount, wall or square pole mount, twin fixture pole mount
- IP rating IP66 for exterior, wet location use
- Weight 6.8 kg (15 lb)
- Included accessories Hanging yoke, termination board, accessory ring for installation of secondary lenses
- Notes Cable diameter: Power 0.36 in / Data 0.34 in
- Effective projected area (EPA): 0.74
Regulatory and Compliance
Approved regulatory standards
- cETLus Listed
- Conforms to UL1598
- Certified to CSA C22.2 No. 250.0
- CE Compliant
