Previously used unit
Fixture Overview
The SolaPix family of wash fixtures from High End Systems takes the traditional concept of a pixel wash and pushes it to its maximum potential. Whether you are using the fixture to spread color all over a ballroom, tradeshow floor, or concert stage, the bright and punchy output will envelop your production with beautiful saturated color. Additionally, when you need to add interest, the narrow zoom and fully macro-and pixel-controlled face gives you a wide variety of looks and effects to help set the mood and steal the show.
Applications
- Live concerts
- Tradeshows
- Festivals
- Industrial shows
- Award shows
- Studios
- Theatre
- Corporate events
Product Features
- Additive LED, RGBW, color mixing system for extremely powerful saturated colors and tunable white control
- Versatile 4.5°–60° zoom
- Extremely efficient optical system provides market-leading lumen output
- FleX Effects Generator for easily customizable macros
- Pixel mapping on all models
- Modular control with Art-Net, or sACN in addition to simultaneous DMX control
- Patent-Pending HaloGraphic Pixel Definition
PRODUCT SPECIFICATIONS
Source
- Fixture Type SolaPix 37
- LED Quantity 37
- Max. Field Lumens 29,000
- Integrating Sphere Lumens 30,500
- LPW 20
- LED Type 40 W Osram Ostar LED
- LED Life 50,000 Hours
Color
- Color Mixing Red, Green, Blue, and White
- Color Temperature Range Variable from 2800–8000 K
Optical
- Beam Angle 4.5°–60°
- Flicker Control/Hz Range 2.4 kHz, 16 kHz
Control
- Input Method DMX (5-pin) or Ethernet
- Protocols DMX via RS-485 Art-Net, or sACN via Ethernet
- RDM Functions
- UI Type Full color graphical UI with 6 button navigational control
- Local Control
- Effects Engine Built in effects engine with multi parameter color and speed control
- Pixel Mapping Individual addressing via DMX, Art-Net, or sACN
Dimming
- Performance 16-Bit, DMX controlled
Electrical
- Max Wattage 1891 W @ 100 V
- Max Current 19.4 A @ 100 V
- Voltage Range 100–240 V 50–60 Hz
- Input Method powerCON TRUE1
Thermal
- Ambient Operating Temp 0°C to 40°C (32°F to 104°F)
- Fan Mode Standard, Studio, User fan control channel
Physical
- Pan and Tilt Range 540° Pan 258° Tilt
- Max Pan/Tilt Speed Pan - 360° in 2.5 s, Tilt - 180° in 1.72 s
- Weight 23.6 kg (52 lb)
- Materials Steel and aluminum frame with molded plastic covers
- Color Black
- Mounting Options Any orientation
- IP Rating IP-20
- Included Accessories: powerCON TRUE1 TOP to bare end fixture tail, Two (2) Omega brackets, Safety cable
Regulatory & Compliance
- Regulatory Standards: Listed to UL 1573, Certified to CSA STD. C22.2 No: 166, EAC
- CE Compliance Declared to the Following Standards : Safety: EN 60598-1, EN 60598-2-17, EN 62031,
- EN 62471 EMC: EN 55015, EN 61547, EN 61000-3-2, EN 61000-3-3
- Complies to the ROHS Directive
Safety
- Minimum distance to illuminated surface = 2.0 m
- Minimum distance from fixture head to combustible materials = 0.1 m
Note: All LED sources experience some lessening of light output and some color shift over time. LED output will vary with thermal conditions. Thermal conditions can be affected by ambient temperatures and orientation.
