Source 4 Par MCM w/o connector
$233.00
SKU:
7061A1026-0X
Condition:
Used
Availability:
Previously used unit
Includes 90 day warranty.
GENERAL INFORMATION
All the power of a PAR plus the cool beam of the Source Four! This is no ordinary par can. Source Four PARs go beyond run-of-the-mill pars with ETC's rugged, die-cast aluminum construction and acclaimed Source Four lighting technology. MCM stands for Metal Cold Mirror. This unique reflector coating ensures that only light, not heat, goes out of the front of the fixture - making the Source Four PAR MCM ideal for orchestra lighting or other performance situations where on-stage comfort is paramount.
PHYSICAL
  • Rugged die-cast aluminum construction
  • Tool-free access to the reflector and lens
  • High-impact, thermally insulated knobs
  • Sealed reflector housing
  • Reflector temperature control through integral heat sink fins
  • Gel frame holders with two accessory slots
  • Top-mounted, gel-frame retainer
  • Steel yoke with two mounting positions
  • Positive locking yoke clutch
  • UL and cUL Listed
ELECTRICAL
  • 115–240 V, 50/60 Hz
  • High-temperature three-conductor 36” leads in a glass fiber outer sleeve
  • Supports ETC Dimmer Doubling technology
LAMP
  • HPL – compact tungsten filament contained in a krypton/xenon-filled quartz envelope
  • 575 W maximum
  • Patented filament geometry makes for extremely efficient light collection and transmission
  • Integral die-cast aluminum heat sink lamp base
LENSES
  • Four heat-resistant, molded borosilicate glass lenses available:
  • Very Narrow Spot (VNSP), Narrow Spot (NSP), Medium Flood (MFL) and Wide Flood (WFL).
  • Round beam for VNSP and NSP, oblong beam shape for MFL and WFL
  • Optional Extra Wide Flood lens (XWFL) also available
  • Tool-free lens changing
  • Thermally insulated lens ring
OPTICAL
  • Modified parabolic and multifaceted reflector
  • Computer-designed reflector facets molded directly into heat sink casting, finished with a metal cold mirror, dichroic coating
  • Cold mirror, dichroic coating removes 90% heat from beam for cooler stage environment
