Previously used unit
ETC Desire D40 Studio lighting fixtures use the newest technology in high-output white-light LEDs to create an ideal luminaire for video, film and other ‘white light only’ applications. Three different LED options give the user a choice for just the right white-light output for the job. The D40 Studio offers a rugged die-cast enclosure, noiseless fan-free operation, multiple lens options and an advanced user interface. The user interface enables easy configuration and specific features for video and film applications. The fixture can be configured to operate under console control for studio systems or in stand-alone ‘no console required’ mode for location lighting.
GENERAL INFORMATION
D40 STUDIO LED ARRAY OPTIONS
D40 Studio fixtures offer three different LED array choices based on specific white-light functions. The D40 Studio fixture is available with any one of the following arrays (not interchangeable) to best suit the intended application.
• D40 Studio Daylight – contains forty 5600 K LEDs for high-intensity, non-variable cool-white output
PRODUCT SPECIFICATIONS
Source
- LED details 40 Lumileds LUXEON® Rebel LED
- Max lumens Studio Daylight: 4,332
- Lumens per watt Studio Daylight: 43.1
- L70 rating (hours to 70% output) 50,000 hours
Color
- Colors used Studio Daylight: White
- Color temperature range Studio Daylight: 3200 K
- Calibrated array Studio HD: Yes
- Optical
- Beam angle 11°
- Aperture size 7.5 in
- Camera flicker control/Hz range: 900–25,000 Hz
Notes Secondary lenses available for multiple beam-spread options
Control
- Input method DMX512 via 5-pin XLR
- Protocols DMX512/RDM
- RDM configuration
- UI type LCD
- Local control
- Onboard presets
- Onboard sequences
- Fixture-to-fixture control
- Notes 15-bit virtual dimming engine
Electrical
- Voltage range 100–240 VAC 50/60 Hz
- Input method Neutrik powerCON in and thru, Requires power from non-dim source
- Inrush (first half-cycle) 15 A at 120 V, 40 A at 240 V
- Fixtures per circuit 10 (15 A via power thru)
- Wattage (typical) 104
- Current draw 0.88 A at 120 V, 0.42 A at 240 V
*Note: All measurements are for 120 V, 60 Hz. Results may vary in different regions.
Thermal
- Ambient operating temp -20°–40°C (-4°–104°F)
- Droop compensation
- BTUs/hour 375.32
Physical
- Materials Die-cast, all metal housing
- Color Black
- Mounting options Yoke
- IP rating IP20
- Weight 6.4 kg (14 lb)
- Included accessories Hanging yoke
Notes Easy access slots for secondary lenses and standard 7.5 inch PAR acessories
Regulatory and Compliance
- Approved regulatory standards: UL 1573, CSA C22.2 No. 166, CE Compliant, EAC Compliant
